hello all about 3 months ago i had a power fc and AVC-R fitted.... diddnt notice till a month or so later because io hardly drive the car that when the avcr is set on either a or b boost it starts to tick once boost pressure gets into the posatives... its a fast tick and is loud enough to hear with the sterio on quietly....
i know its the avcr because when i turn boost a or b to off the doise dissapears....
PLEASE HELP with any ideas on what could be causing this or how i could get rid of this ticking noise..... anyone had the same problem?
many thanks in advance :D
jenkies
It's fine. That's a normal noise.
It makes that noise when you're on boost, because the solenoids that were installed in the engine bay are opening and closing to control the boost. To make it quieter, mount the solenoids on some foam, and not directly onto metal.
ahh thanks champs yeh ill mount it on some rubber or something.... gets bloody irritating thats all... simple fix leave avcr boost control to off unless extra boost is needed.
:D
  • 3 months later...
    • SO whats the deal with this issue? I've read a heap of posts from the infinity owners in the US having full engine swaps done under warranty. Most claims are done on earlier cars than 2019 but I'm sure I've come across claims of 2020 models also having this issue. I like the 400r and Q50Red/S but can't fathom dumping close to 50k on a car with terminal issues!!!
    • The above video is working normally. That is, that's how the right hand indicator should cancel when rotating the wheel left.
    • I noticed that I could see creatures on the moon when I turned my new headlights on. I thought I should check the alignment. It's pretty rudimentary but I just grabbed some dry wall and put it against my tablet and made sure the beam was below the height on the headlights. Ie the beam is at 600mm on my car, I just made it lower than that 7.5m away.  Not the best but it'll do until I can do it properly at the local shops.
    • As @Duncan said - the bores are most likely to cop it. But anything can and does happen. Rods are cheap. Rods are good. The work to rebuild the motor will be 30x the price of rods. You won't notice it.
    • Yeah car has 110 on the clock. That said the front turbo (that exploded) doesn't seem to be the original, it has a S1 part number but the car is a series 3. Yep, in the cat is where I first found the turbine wheel pieces - a couple decent sized ones, then a whole lot of fragments.  I agree, probably makes sense to upgrade parts that are being replaced. Things like rods would be 'nice' but realistically it seems unlikely they would need replacing. I was hoping that it was a case that they generally f**k up the valves but not the bore, or vice versa. Is it generally the scour damage rather than ceramic bits getting mashed into the piston tops / valves? I tried a search but couldn't find any threads with pics from the guts of a motor that's had this happen.
