hey guys, just went to WSID and was happy with the time i pulled 13.75 with only a cat back and 10 psi boost...HOWEVER, the last run i shifted from 3rd gear redline into 2nd gear, would this of damaged my car engine (such as pistons working too hard?) or would the rev limiter cut it off even if u shifted from 3rd to 2nd???
wat are the possible damages i coulda done??? cuz my car runs alright but just paranoid man
  • Replies 54
hey i saw your car! i wasnt competing, but i would like to in a few weeks, 16th methinks.
didnt see the mis-shift, and im no techhead but i have heard it can do all kinds of things such as valve-bounce, the piston coming up and smashing into the valve. of course that is just heresay, if its running fine i shouldnt be too concerned.
not like that poor bmw that got towed. or whatever it was that shat its guts up the end and delayed proceedings.
ill race you if i see you there again. mind you im expecting mid 12s with a 230-240rwkw R33. :D
if u shifted to second from 3rd wen u were on the limiter id be more concerned about ur gbox and driveline hence a massive compression lock usually... but if u had sticky tyres well i dont know but i wouldnt have thought it would have affected ur engine much cept for pinging of limiter
yep the gearbox is actually quite fine imo...
i didn't have sticky tyres, i only had some low profile "roadster" tyres at rear...and wat do u exactly mean by driveline issues?
i shoulda mentioned before, i did smell something badly right after it happened whether its the clutch or brake pads i don't know but there was no smoke or bang noises...
but the thing is i thought the rev limiter woulda cut it off so i woulda been safe? or am i just lucky the pistons didn't fly out?
well the way i figure it, if you let the clutch right out, there is nothing stopping the engine from doing say 10000rpm. the rev limiter wont prevent this, it only cuts the spark (or fuel?) in an attempt to drop the revs. remember, if the tyres are going 150kmh, this speed is transferred through the drivetrain, and then to the engine. in 2nd this would = 10500rpm.
this normally results in compression skid, where the tyres lock up, or the engine doing 10000rpm momentarily lol.
hopefully that was your clutch slipping. best possible result! burnt clutch smells like shit, i daresay thats what it was. :D
oh alright thanks ALOT GUYS! just bloody paranoid after that....
but yeah like u said the tyres did lock up and made me skid~! so does that mean the rev wouldn't of gotten to 10000rpm? or it still would have and kinda stuffed up my pistons u reckon?
oh yeah another thing is, when i tried to step on it on 2nd gear after i mis-shifted, the rev went up as if the clutch was slipping, i thought that was the rev limiter kicking in? or is it really just a clutch slip?
Edited by R33Turbo
yes the revs probably did get up to 9-10000. i think its worse for your valves than your pistons, but if something let go it would probably have happened instantly and been catastrophic. so dont do it again lol.
revs going up, but not speed, is generally a good sign of clutch slip.
why don't you give it another run? because if the valves did bend due to the mis shift then wouldn't the performance be affected in a bad way ? or maybe not? can someone correct me on this?
thanks for the input guys. well im taking it in for a compression test tomorrow to make sure, but apparently to find out for sure i need to pull apart the head
*sigh* shouldn't of went to WSID tonight
Edited by R33Turbo
SoSK did similar, 4th to 3rd instead of 5th. Result 12 bent exchaust valves, no compression, engine no run. If the engine still runs OK, then chances are you got away with it, consider yourself very lucky. A leak down test will confirm that everything is OK.
Cheers
Gary
    • Yeah saw that video on YouTube. But he got a R grade (repaired) high mileage model and proudly advertised the fact it was super cheap and no doubt with issues. I wouldn't be going the cheap and nasty route.
    • I don't really know general street pads too well, but there is no reason you can't get a low dust, long wearing, no squeal pad that works for those calipers at a reasonable price....they would just be a low end to medium price daily style pad.  If new pads don't have much bite or they loose it over time, it is probably just the pad glazing up which you can fix by giving them a good thrashing every now and then (or get the mechanic to deglaze them at next service) Track or semi track pads are where you have to put up with excessive dust (and potentially squealing as a side effect of that) in return for good bite and performance when very hot. Street pads have nothing like that sort of punishment, even long downhills with the brakes on are easier than a track session
    • lol yeah I'll check that, reminds me of the LDV thread!  I don't think that is the problem here, the starter doesn't even solenoid click. I did do a super quick test by removing the starter motor's power cable from the engine bay fuse box and the battery voltage was still 10v, so something super fishy is going on. BTW here is a R33 fuse box table I threw together from a few sources....use at own risk! R33 Fuse Box and Sources.xlsx
    • Johnny's approach, throw all the Nissan electronics into the trash. Best thing I've done to my shit box, go DBW.
    • Sounds like the JAX guys must have installed some really awful pads, are they BenShit/BenDicks pads by any chance?
