LOL @ anyone saying the rev limiter would have stopped it.
Of course it doesn't. All it does is cut fuel.. If the engine is being forced to rev harder, then nothing is going to stop it..
Reminds me of the guy driving multi-tyred road roller, big hill behind Hervey Bay.
Cooked the brakes but he decided the compression would hold it....
Poor old Perkins did at least 10,000rpm, threw rods, pistons before she crashed and burned.
  • Replies 54
My mate did the exact same thing in his R31 which runs a NA RB30DE.
He ran 14.0 I think.... maybe a tad faster
The car has like 12:1 compression.
He said he shifted at like 7000rpm and the car just ripped up to like 9500rpm before he pushed the clutch back in.
It did nothing to his car that he can tell and its been about 4 months or so since and hasn't noticed any thing.
just a question on your question.. WHAT THE F**K!!! how did ur synchros even manage to get it into second?? from thurd?? lucky it diddnt shit itself there and then auto would deal with this altho a manual well different story the amount of load put on your engine and driveline would be like a cop pulling ur arm behind your back till it snapped... if nothing is wrong then all the best and good luck :P
My mates R31 was manual and he said the syncos loved it. Went strait in with out a problem.
Its not going to do as much as you think it is as the engine isn't making any power.
Clutch would slip or wheels would light up before it did any damage. Clutch dropping a car with lots of grip from rev limiter would be worse.
yeah didn't get to do the test yet but cuz im so impatient i went for few runs already dropping it into 2nd then rocketing it :P but the engine didn't blow UP so im guessing its okay...
anywayz i been told by UAS to do leak down test and been told by nathan from grey imports to do compression test, hell im so confused on which test to bloody do, might just do both!
wat u guys think?
Edited by R33Turbo
not sure mate, dark blue maybe black. i believe it was a 2door 3 series. but that is a slightly educated guess only.
Gotcha, so it was a newish model. Most likely one of the S/C one's that run around.
Just do both tests, a leak down and compression test will tell you what shape the engine's in, cost wise it's fairly cheap for peace of mind.
but if the valves did bend or something, would it be noticable when driving normally?
Im assuming my clutch slipping when over-rev saved my engine cuz if it didn't slip maybe i woulda blown the engine
Edited by R33Turbo
It's fine.
if there was a problem, like it has been said, it would have been a HUGE failure. like get a tow truck home failure.
a few years ago, there was a link being sent around to a US honda forum where some guy was doing a run on the freeway in his DC5R when they were new.
shifted from 4th at 8500rpm to 3rd instead of 5th.
resulted in what looked like the end of Terminator 2, where the liquid metal terminator is in the lava shit.
go do a regular service with new oil and oil filter for the engine and maybe change your gearbox oil and diff oil for good measure too.
my mate in his 93 Prelude did a similar thing.. he was racing and evo on the motorway.. they were doing around 120 or something i dont know. He dropped from 5th to 2nd. over-revved to like 10000or woteva.
hahaha. his engine was a mess. needed a tow truck hahaha. needless to say he needed a new engine. stupid honda's.
f**king hell what does down south have to do with yourbloody 1/4 times.
No car in QLD (heat taken into account) gets close to the times down there!
What MPH did you run on the 13.75 run? And wat 60ft did you do?
I just wanna compare cause our cars are running the same mods and should be relatively even
For note, im pulling 14.7 @ 97MPH (not holding boost well as i dont have a ebc, but running a peakish 11psi drop back) with 2.3 60fts (i know thats my problem too)
but it wont net me a whole second getting it down to 2 flat
yeah apart from the mis-shift im quite happy with the time i got considering the mods...
60foot time was 2.14 something and it was at 161km/hr...
when i got 2.4 something 60 ft time my 1/4 time ended up to be 13.9 ...so 60 foot time is the most important, however i have no idea why ur pulling 14.7 it shouldn't even be that high stock... thats wat non-turbos do
BTW my boost doesn't hold either and ends up dropping to around 9 which i was complaining about but im assuming its normal for stock turbo
Edited by R33Turbo
hmmm... the 60ft your doing is still pretty slow. im running around 3mph slower, which isnt major. there will always be some difference with cars etc, but over all pretty close.
I truely am starting to believe the track i race on (benaraby raceway, less then top class) may have some sort of differences/timing problems.
every car i watch there pulls so much then the equivalent down south.
either way, thats hauling ass dude. i would get you to drive my car if you can pull those times!
i dont know whats with my time either, my mph is healthy enough!
congrats to you either way!
what rims and tires are you using, and can you share you launch technique?
Edited by Granthem
    • Man, different parts but the same numbers is terrible @dbm7! And it doesn't help that most online shops don't list the part numbers at all. They just give a list of compatible models...
    • Slow when hot could also be because its getting more dynamic compression, OR things are getting a bit tighter once it is all expanded. If it were an earthing issue, typically I'd expect you to have it have issues all the time. Unless it's really a combination of both things. Where the higher compression, and things being a bit tighter, is giving that bit of extra load and you do need a slight clean up on the cables/connections.
    • Yeah, this is one of the most annoying things about nissan part numbers... I've got an unrelated example... Image is of the AT output shaft ~ they have the same part#, but clearly the shaft on the left is beefier design to that on the right ...the difference (essentially) is the 'lighter' shaft on the right, is for engines up to RB25DE (this includes RB20 variants) : the shaft on the left is for RB25/26DET(T)....are they interchangeable? Yes...but obviously one shaft is going to be stronger than the other...and, the lighter shaft is around USD115, but the heavier shaft closer to USD150...same part#... ...epc-data usually tells a tale ~ the amayama listing for 39100-23U60 has a note "Longest side is between 60 and 105 cm" ; no such info is there for 39100-23U70 ...and given the great disparity in price between the 2 parts, it makes me at least curious (to the point of caution) where the 'extra money' went? ...ie; these 2 parts have a cost difference that (to myself at least) isn't explained by 'plastic boot'...ie; with amayama there's AUD700 price difference ...plastic versus rubber?...I'm not seeing it like that...and 60cm ~ 105cm...??...that's a huge disparity....something hinky going on here... I'd try searching by VIN, not model... /2cents
    • I don't know for sure, but I'd expect them all to be interchangeable given the diff end and hub end don't move/change between any C34 series. Often Nissan will change part numbers and the aftermarket follows those year ranges; but the original part number change doesn't mean other parts won't fit. The change could be a change in material, internal parts or even just supplier. For example, all the RB gearbox to engine bolts are no longer available and there is a new part number instead. The only change is they went from cadmium plated bolts to zinc plated due to the issues manufacturing with Cadmium. They look different but work the same.
    • One year is a bit concerning. Did you try contacting GSP? It says 5 year warranty on the box if I remember correctly. I'm also running their driveshafts on my S2 Stagea.   You could check the part numbers on Amayama for your year. Here's the link for my 1998 which gives the 39100-23U60 part number. Well, that and 39100-23U70. https://www.amayama.com/en/genuine-catalogs/epc/nissan-japan/stagea/wgnc34/6649-rb25det/trans/391 What does it say for yours?
