Hi Guys..
I have done a search but couldnt find anything relevant.
I need to know if any changes occur to the accuracy or responsivness of a boost gauge if the diameter of the vacuum line that feeds it is increased.
The increase would only be small (ie/ 2.5mm to 3 or 3.5mm).
Am i correct in thinking because it is a closed circuit of air that the responsiveness may suffer but the gauge will still eventually be accurate?
Let me know your thoughts.
Cheers,
Daniel
nitestalkr, unless ur talking bout hoses feeding a input system like a map sensor (which can be mounted close to the pressure source anyway) i wouldn't worry bout the v.small +/_ in response time. How often are you looking at the gauge when quick pressure changes are occurring? I think a gauge is really only a rough indication anyway, specially when the needle is moving quickly.
Again, this doesn't apply to A>D conversion, like map senders, logging box's etc feeding closed loop systems.
To answer your Q more, many gauge sets come with a small ID nylon line, instead of normal wider vac hose.
Edited by GeeTR
Thanks for the replies guys.
To follow on from what you have said, its really the accuracy i was more worried about as im trying to dial in 12psi which is getting to the pointy end for this turbo (standard 34 GTT turbo), and i am relying a fair amount on the end accuracy of the boost gauge to judge this.
Response time isnt a massive concern because as GeeTR eluded to, i dont look at the boost gauge often at all once i have dialled my optimum pressure in. Aftermarket gauge is already behind in response time to the standard one anyway, so really not a concern.
Cheers,
Daniel
