Hey guys
I've got an R34 GTR VSpec II and am about to do some mods to her.
R34 N1's
700cc Injectors
Walbro Pump
Apexi PFC
HKS Intake
Exhaust w/ High Flow cat
I have Z32 AFM's also which im trying to decide whether to fit or to sell, for the power those mods will produce (Hoping like 350 - 400rwhp) will i need Z32's? If not what kind of power will i need to be making to justify them?
Also, as far as the mods go, is there anything i have overlooked that will add easy power to the car that i should be considering? (Been told not to look at Cams or anything as the R34 GTR's don't really need them for that power, but i don't know how true this is)
Thanks guys!
Do the R34 GTR's come with N1's as standard?
Thinking about buys a 34 GTR ;)
No. Normal R34GTR turbos are ball bearing with ceramic tubines. The N1's have ball bearings and steel turbines, look very much like GT2530's and are capable of around the same power.
Cheers
Gary
I would stick with what you have at the moment and see what afm voltages you get...if they are not close to going full scale I would leave them.
The reason for this is if you went for z32s and they were only measuring upto say 30-40% of full measurement scale or voltage, you are not using the full input resolution of the ECU and technically you are losing precision in your tune..The ECU uses an A-D converter to convert voltage into a digital number. Not analogue. So voltages are either rounded up or down to the nearest value. If the ECU has an input range of 0-5v and you are only using 2v of that range then between each corresponding digital value would be higher and the resulting error would be higher..
An analogy to this,
If wanted to measure the length of something that was 87mm in length and you had either:
1. A 1 metre ruler with 1cm divisions
or
2. A shorter ruler say 300mm long divided into 1mm increments
The best option would be option 2 for measuring the 87mm. The 1m ruler would see it as (9cm) 90mm and not 87mm
Hope this makes sense..
Oooops, sorry, mis-read it... HP..! i got 303.1Kw at wheels similar plus internals and flowed head, flashy filters etc, plus FPR plus good boost controller plus more too.
N1's are superb Road 'bines tho, stick with them. there are a few variants as well i am told too!!, but i unclear what the variants are.
Good luck, enjoy the results, its a good start u got going there.
My orig's maxed out at just short of 300RWKW. btw.
R34's have smaller turbo potential than orig GTR ones too. Get some Orig GTR32's, more power from them, but still ceramic exh impeller am afraid , but better turbos than R34's
Edited by Richieb
An analogy to this,
or
Thanks a lot mate that does make sense (as an engineering student your analogy was right on the money to what i've been taught lol)
Thanks everyone else for your input also, ill leave the stockers and see how they fare and swap them out if necessary! Thanks!
sorry to hijac but...
Is this correct? Thought the standard 34 gtr turbos would flow more than the stocka 32's?
mike
mike
No standard 34 turbos are slightlty bigger than 32+33 and better because they are ball bearing but still have ceramic turbine wheels .
R32 - 0.42a/r compressor
R33 - 0.42a/r compressor
R34 - 0.53a/r compressor
http://homepage.ntlworld.com/tbroom/Turbos.htm
very useful for comparing stock turbochargers, lists all specs, wheels, trims, housing etc
Got that one paul, but the opinion here is stiil the best ones are the R32's.
R34 spool up quicker, but run out of steam. The Compressor wheel is smaller.
Edited by Richieb
An analogy to this,
or
+1 :spank:
What topic was being discussed?
OH..AFM's....... :laughing-smiley-014:
RB20 or RB25 just plug in ...that is what I have gone with.
But if you got $$$...Nismo all the way..at least you have bragging rights...... :banana:
ive still got my stock afms... made 287.8kw @ all 4's... that was on 15psi.. after that i ran tad over 17psi which is slightly over 300kw @ all 4's and afrs were still good...
they look like stock afms anyways.. as were injectors and fuel pump lol.. the stock GTR gear is pretty serious stuff really
hmm sell the z32 afm's. sell your standard ones. use extra money for a haltec or my personal favorite (short of 10g plus motec) the new wolf v500.
just buy something that uses a map sensor and be done with it
MAP sensor and multiple throttle bodies are not a good mix for a road car.
Cheers
Gaery
    • No not yet.  Hopefully this weekend if I can pluck up the confidence!  I had to sit in the car at one point yesterday to unbolt the rear struts.  As mentioned in an earlier post when I was putting it together there is still a bit of rotation possible so when I sat in the car, it rotated a little bit.  I near shit myself thinking the whole thing was coming down!  I do 99% of my own shit in the shed but I think I might call on some assistance the first time I spin it!
    • Strong first post. On a Skyline-centric forum. Have you considered actually going out into the world, visiting the actual dealership, and asking the parts guy over the counter? Or at least just call them up on the phone?
    • Should shit that in as for the driver ability probably not
    • Trying to find the plastic under cover for an 04' Forester X. The main under cover that covers most of the front of the vehicle under the engine. This has turned out to be a crazy experience. Normally I can find parts for vehicles, if I have the correct info, no problem. But not this! The Forester is a non-turbo btw. In a Forester parts catalog, for model years 03'-06', it shows part# 56410SA070 as being the correct part. So I go to the local Subaru dealership's website to order it. I type in the part#, hit search and there it is, the under cover. "DOES THIS PART FIT YOUR VEHICLE?" I type in my VIN# and sure enough, "This Part Does Not Fit Your Vehicle. See Similar Parts For Your Vehicle." I click on that and part# 56410SA000 comes up. Looks absolutely nothing like the previous part. Not even close. So I go to a different Subaru dealer website and put in that 2nd part# (56410SA000) and "This Part Has Been Replaced By" 56410SA070, which is the first part I looked up. I thought OK, makes sense. They replaced the strange looking part, with the one I looked up first, so I add it to the cart. "Does This Part Fit Your Vehicle?" I type in my VIN#, and sure enough, "This Part Does Not Fit Your Vehicle." I've basically been doing this with various parts suppliers and dealerships, for the past 4 hours! Does anyone know what the hell is going on?? Thanks in advance!
    • have you rotated the car yet? if so how smooth was it?
