Drags are on tomorrow night.
What do y'all think I'll get with a 2-2.3 sec 60ft?
Car is R32 GTR (in rwd)
340rwhp
275 Kuhmo tyres around my 19s...
OS triple plate clutch
I'm hoping for somewhere around the 13 flat mark as I haven't had the car that long yet and I'm not the fastest gear changer...
Any input on how to launch rwd cars etc?
https://www.sau.com.au/forums/topic/213298-qtr-mile-times-for-my-32-gtr/
12.48 if u run it in 4wd :D thats my guess 275's great traction trip plate clutch= negative on the clutch slip if uve got 4wd use it bud and u will clean up :P
Edited by jenkies
Depends if you can keep it boosting chris.
All that lag is eating up the time. thats why you should downgrade that turbo or make some more power with it so that when it does hit its worthwhile :)
Trading off that much response for 240rwkw isnt really worth it. Get it retuned to run the boost it should be! 25psi! lol
You better be doing quicker then what my 165kw commodore did in RWD this time chris! hahahaha
Edited by Granthem
actually it was a semi-final >_<
i like no.11 too "had too much grip"
and no.14 "had too much power"
Final as in quarter-final, semi-final or final. I would never credit you with making a final round anywhere mate. That's what your missus is for. :(
haha.
Well its in rwd because the 4wd is broken. Something wrong with the oil control switch...
Yeah grant, it'll run better than your commie. And when you learn how to tune my power fc for free instead of me having to drive 8 hours i'll get it tuned! :D
Nah, next brissy trip i reckon ill get it tuned for around 18psi.. depends how the injectors go. they're at 90% now but its also ridiculously rich.
Couldn't get the power down AT ALL>
Worst 60ft times you would have ever seen lol. Got in a few runs, but just couldn't work out the best way to launch with this clutch.
I think my best run was 14.7 at 107mph with 2.843...
Other runs:
14.7 at 108mph with a 2.874 60ft
14.9 at 106mph with 2.83 60ft
16.5 at 103mph with 3.06 60ft
15.4 at 104mph with 2.92 60ft
15.1 at 106mph with 2.96 60ft
15.2 at 102mph with 2.75 60ft
20.6 at 45mph...missed 3rd lol. still only had a 3sec 60ft though.
Any ideas on the best way to launch with this type of clutch?
Next time I will soften the rear coilovers as much as I can... Don't want to have to buy slicks as I like it to be full street times, but I might.
Forgot to mention, although its obvious... 275s did absolutely nothing. I ran better times on half the boost with 245s. Kuhmo Ecsta are not a great tyre at all. Couldn't even get traction in 2nd gear.
go back! u can do better! lol
LOL. I'm determined to get a good time in rwd now. Any good ways to launch other than riding the clutch?? Someone on here has got to have similar or more power and run on street tyres.......
I think you meant 14 sec GTR.....................
No, it's not slow. You should know that after driving it to and from last night. Just a bit slippery at the start line. Reeled in that commonwhore last night pretty easy!
Edited by NoFX_Hardcore
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
    • The Frenchy's kit is the way to go forward. A modern compressor that weighs about 1/2 as much, is at least twice as efficient, and will do a good job on R134a. And of course the kit has everything else you need to connect it up and have it work properly.
    • Hey all , I am in the process of having the AC system in my r32 GTST converted from r12 to r134a and I’m being told my compressor has gone bad and I will need a new one. I was wondering if anybody has any suggestions for what is the best route to go aside from dropping $1500 on a new oem one? I did see that Frenchy’s performance garage offers a kit to mount a Toyota compressor, has anybody actually used this kit on their car? Or is there anywhere I could purchase just a clutch? Any help is appreciated.
    • Well, your RB20 ECU loom won't have wires for the boost solenoid, that boost sensor, and possibly one or two other things. There could be differences in seemingly random things like the charcoal canister purge solenoid, because the 25DET has to handle boost in the vacuum system and the 20DE does not. I don't know - I haven't looked. It is very likely that all the most important things are same-same, being the main sensors like AFM, CAS, etc, and the injectors and ignition. Not that you'll need the AFM for the Haltech anyway. I would suggest that you would seriously want to sit down with the pinouts for both ECUs and just go through them and highlight green what is the same, orange what is different/missing, and make a plan from there. It's not going to be difficult. It will either be the same or need to be fixed.
