Qtr Mile Times For My 32 Gtr?
Drags are on tomorrow night.
What do y'all think I'll get with a 2-2.3 sec 60ft?
Car is R32 GTR (in rwd)
340rwhp
275 Kuhmo tyres around my 19s...
OS triple plate clutch
I'm hoping for somewhere around the 13 flat mark as I haven't had the car that long yet and I'm not the fastest gear changer...
Any input on how to launch rwd cars etc?
12.48 if u run it in 4wd :D thats my guess 275's great traction trip plate clutch= negative on the clutch slip if uve got 4wd use it bud and u will clean up :P
Edited by jenkies
ive used several including one similar to 24
No.43 "forgot to switch it back to 4WD after the burnout in a final, interstate and when it counts most!"
:thumbsup:
Fixed.
Depends if you can keep it boosting chris.
All that lag is eating up the time. thats why you should downgrade that turbo or make some more power with it so that when it does hit its worthwhile :)
Trading off that much response for 240rwkw isnt really worth it. Get it retuned to run the boost it should be! 25psi! lol
You better be doing quicker then what my 165kw commodore did in RWD this time chris! hahahaha
Edited by Granthem
actually it was a semi-final >_<
i like no.11 too "had too much grip"
and no.14 "had too much power"
Final as in quarter-final, semi-final or final. I would never credit you with making a final round anywhere mate. That's what your missus is for. :(
haha.
Well its in rwd because the 4wd is broken. Something wrong with the oil control switch...
Yeah grant, it'll run better than your commie. And when you learn how to tune my power fc for free instead of me having to drive 8 hours i'll get it tuned! :D
Nah, next brissy trip i reckon ill get it tuned for around 18psi.. depends how the injectors go. they're at 90% now but its also ridiculously rich.
Couldn't get the power down AT ALL>
Worst 60ft times you would have ever seen lol. Got in a few runs, but just couldn't work out the best way to launch with this clutch.
I think my best run was 14.7 at 107mph with 2.843...
Other runs:
14.7 at 108mph with a 2.874 60ft
14.9 at 106mph with 2.83 60ft
16.5 at 103mph with 3.06 60ft
15.4 at 104mph with 2.92 60ft
15.1 at 106mph with 2.96 60ft
15.2 at 102mph with 2.75 60ft
20.6 at 45mph...missed 3rd lol. still only had a 3sec 60ft though.
Any ideas on the best way to launch with this type of clutch?
Next time I will soften the rear coilovers as much as I can... Don't want to have to buy slicks as I like it to be full street times, but I might.
Forgot to mention, although its obvious... 275s did absolutely nothing. I ran better times on half the boost with 245s. Kuhmo Ecsta are not a great tyre at all. Couldn't even get traction in 2nd gear.
go back! u can do better! lol
LOL. I'm determined to get a good time in rwd now. Any good ways to launch other than riding the clutch?? Someone on here has got to have similar or more power and run on street tyres.......
I think you meant 14 sec GTR.....................
No, it's not slow. You should know that after driving it to and from last night. Just a bit slippery at the start line. Reeled in that commonwhore last night pretty easy!
Edited by NoFX_Hardcore
 Share
    • That's the most absurd thing I've ever heard. I would go cut bellhousing over that monstrosity of a flywheel all day, every day. It puts a lot more mass further from the last main bearing. I've had nothing but problems with Collins in the past and refuse to ever buy their products again. I would not trust anything they tell you. He's playing his salesman card.  I'm currently at 640whp on a mustang dyno (~770bhp) with the intentions of running E85 and a lot more power this upcoming spring. Cheers,
    • Nah, it's not the reduced knock margin. It is a direct mechanical effect of having to initiate the combustion earlier, while the piston is still rising, which starts to exert combustion pressure on the rising piston earlier, making the rest of the engine work harder to finish driving the piston up to TDC where the combustion pressure stops being a negative and starts being a positive. Your modern engine that only needs ~10° to make MBT doesn't waste the other 10 or so degrees of crank rotation. That's almost all of it. The difference in knock margin might go either way. Remember that modern engines to which you are currently comparing the long tractor engine (the RB) are now running super high compression, direct injection, tricky cam control and maybe even cylinder pressure sensors. You're not comparing apples with other fruit. It's apples and sea weed, or some other evolutionarily primitive vegetation. And remember, squish only really comes into play at the very end of the stroke. It certainly does good things, but it is not the biggest contributor to what's going on. It is quite possibly much less important in 4 valve head than 2 valvers also, because there is so much less squish available to a 4 valve anyway.
    • Food for thought, a longer stroke motor would need less ignition timing vs. a shorter stroke motor requiring more ignition timing.
    • Thanks Duncan, HART is only 10 mins from me (I did my bike license there), it'd be awesome if it ran these types of things.  Sutton Road does look good and they take fewer cars than SMSP which is good.  Surely you have enough land to lay a few million tonnes of concrete and some sprinklers D?
    • I thought an engine that needs more ignition timing to make power is going to result in less power due to reduced knock margin? More time for the combustion to propagate -> more time for it to heat up the rest of the mix to detonation.
