hey guy's just asking the turbo guru's here if its possible to correct the massive mix match in housing/wheel design that is present in the gt2876r... the turbo is strapped to a rb25 and is rediculusly laggy for not alot of power or "punch" spec's are :
Turbine
-Wheel: 53mm w/ 62 trim
-Housing: .64 ar
Compressor
-Wheel: 76mm w/ 48 trim
-Housing: .70 ar
4inch front mouth
its for a moded std manifold...
please no suggestion's of changing turbo's etc at this time, as i would like to explore the possibility for changing housing's etc...
https://www.sau.com.au/forums/topic/213319-2876r-downsize/
say for example, 1 bar actuator presure. 2nd and 3rd gear approx fullboost @ 4500 rpm... this is untuned though, running old tune from std turbo, however i cant see the turbo getting anywhere below what i'd be happy with...
https://www.sau.com.au/forums/topic/213319-2876r-downsize/#findComment-3768006
Your call but your not going to fix that thing with housing alterations , the only genuine option is a larger .86 A/R turbine housing and that will only give it more turbine lag .
The problem is it has a modern low blade count light weight 54mm diameter turbine trying to drive a dinosaur 76mm T04S compressor wheel . Changing housings won't alter the fact that its compressor is a really bad match for its turbine .
Why Garrett continue to sell those POS things I'll never know .
IMO it has to go if you want you car to be lots better .
Sorry , A .
https://www.sau.com.au/forums/topic/213319-2876r-downsize/#findComment-3768439
Are you sure about that turbine trim? It should be the same as a 2871 rear end.
The only way you could make that turbo usable is to replace the whole front end. I would suggest .5 A/R generic t04e comp cover and backing plate, with a 71mm 52 or 56 trim compressor.
By the time you get the work done and supply the parts it'd be cheaper and easier to just find a second hand replacement 2871 on NS and sell yours. They all seem to be going bigger these days for some reason, you may even find a sucker to buy yours :thumbsup:
https://www.sau.com.au/forums/topic/213319-2876r-downsize/#findComment-3768884
By the time you get the work done and supply the parts it'd be cheaper and easier to just find a second hand replacement 2871 on NS and sell yours. They all seem to be going bigger these days for some reason, you may even find a sucker to buy yours :D
no way.......NS members are way too astute than to buy a 2876 - thats only something a skyline driver would buy :laugh:
https://www.sau.com.au/forums/topic/213319-2876r-downsize/#findComment-3770950
    • Come to Eastwood, you'll get plenty of that 馃ぃ
    • Oof, I will forevermore have those shredded gears in mind whenever someone talks about showing mechanical sympathy towards their car. Thanks for the photos, fascinating stuff!
    • Curious to see how the SpeedTek stuff holds up
    • The holdups last year were drivetrain related. I had the car out right after getting the bearing issue resolved. Third launch and the car didn't move after releasing the clutch. It had sheared all the engagement teeth off the 1st gear.    Thankfully no other damage was done. I set an aftermarket gear beside an OEM gear and found that the engagement teeth on the OEM gear were much larger and better supported. Looking through my bin of spare transmission gears I found that there are two types of tooth on the OEM first gears - the larger tooth and the smaller tooth. It looks like most aftermarket gearset manufacturers base their design on the smaller tooth. OEM large tooth left - Speedtek, OS Giken, etc or OEM small tooth right Decided to give that larger engagement tooth a try. Pressed the ring off an OEM gear and sent it to a transmission manufacturer here in the States. They did their "faceplating" operation with my synchro ring on the Speedtek gear.   I reassembled it, took it back to the track and promptly destroyed the gear itself.  I'll rebuild this and use it as a spare - thankfully just first gear and the countershaft are damaged beyond repair. Definitely disheartening but my welded on engagement tooth ring held up!  Moved to Speedtek's dog engagement design as the gears appear to be much stronger. So far they have taken much more abuse at the track. Also scored a Stillway lockout from the Netherands for super cheap. It's for some other RB transmission so it took a bit of fabrication to fit but honestly a very easy job. I also had to heavily modify the gates as they were very different.   Then for some reason at the last test and tune a silicon coupler below the throttle blew off and took out the radiator and fan. Thankfully it was in the burnout box and not down track. This car is really beating me up - I still haven't made a pass in it. Ran it through the gears many times on the street but it keeps biting me at the track.  Currently in the process of replacing the radiator and remaking the throttle pipe to remove the coupler and use a cast 90 and a vband. I WILL get this thing down the track...
    • Covers most of the above points really. There's a few exceptions but most just see driving as an irritating but necessary task they must complete if they want to get anywhere on time. Also see it as a good time to show their awesome multi-tasking abilities on their mobile and/or doing their makeup.
