Unless your existing injectors and/or fuel pump are a restriction, doing nothing but changing your injectors and pump will not give you a performance improvement. If I remember correctly, at anything less than around 220rwkw (give or take a bit) it's unlikely you'll need to change either.
Keep in mind that changing how much fuel the engine is getting will most likely mean a retune, and if you have the stock ECU, you'll have to replace it with something that can be tuned.
Yes as putting in larger injectors and not changing the tune means it will be pouring more fuel into the cylinder each stroke...
Hence you will burn through fuel like no tomorrow...
In short, to make more power you need;
1. More fuel
2. More air
3. More ignition or at least just good clean ignition
Of course for all this to work you ned to balance the above and fine tune the quanities of each of the above listed...
So in short bigger injectors by them selves will do bugger all...
That also said, if you arent going for insane power, you might be able to get away with a bigger pump and an aftermarket fuel regulator, just enough to force that extra bit of fuel through.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
    • 😜 hopefully we get this instead of a new R36 GTR due to recent financial problems at Nissan. Nismo to sell a complete kit with RB26 and driveline. All starts making sense (ok maybe not) once the Nissan Leaf's (Leaves?) with stuffed EV motors/batteries hit the market cheap
    • Hi guys , have had allot of time for SAU and has helped me out heaps in the past so I thought I would give it a go , I have my QM1 white NUR for sale 1 of 156 examples built by Nissan. Serious personal messages please if interested and details will be provided , asking 500k
