After years of nagging my wife she finally said i could get my dream car. The next day i was at the car dealer putting in an order for a R34 GTR. Week later a VSPEC was found and was on its way over from Japan. Took 5 weeks to get here then another week to comply. Another week was spent adding minimum mods - titanium exhaust, ebc and filter kit. Also added a nismo kit and painted front lip (not diffuser). Lastly added 2 alarm system for peace of mind. All up 8 weeks to get into car (felt longer).
Have always wanted one since I saw a brand new R33 GTR in 96. Have always known it was the best car even though i had never been in one. My first time was when I drove off the lot with MY OWN GODZILLA. Had high expectations for this car and it has more than exceeded them. The pure driving pleasure it gives is the best.
My dream has come true and i hope yours does too..
Edited by kefe69
https://www.sau.com.au/forums/topic/213321-finally-got-my-dream-car/
firstly welcome to sau... and firstly again CONGRATULATIONS! welcome to the club of opening your beer 5 meters away from your car and facing the front bonnet... holding up your beer to the car and saying cheers :P ..... u will be doing it for the next 2 months...... u will talk to her an develope a deep bond..... i know i did when i purchased my immaculate r32 gtr 6 months ago. there is something about a gtr that pulls you in and you will quickly develope more respect for this car than you ever thought possible and it will keep exceeding your expectations... especially through the twisties (hills)
ontop of that your beast is absolutely stunning.... a real eye brow raiser! good luck with her and welcome to the empty wallet club....... LET THE MODDING BEGIN! :cool:
all the best
jenkies
Im not the only one drooling over her, ive noticed other people around her doing it too.
I know what you mean! I had a WRX before, but I've never seen people react the way they do to the R! So many people stop and look.
snip...
how much is the FOB? what dealer did you use?
thanks :P
  • 1 month later...
It is a feeling you can't describe owning the GTR. It is the only car you will drive that will always ask questions of you as driver. You can go faster through that corner you know, comeon faster. It is a question of nerve, are you game enough to push it, the car is always asking you and telling you could do that faster. Once you get that thing on the track or at a DECA day you will understand. :geek:
Well done mate, I've got the exact same colour and spec GTR some two years ago now...still remember picking her up and the drive home...can't beat that feeling....you know what I mean!
Anyway, some months ago after telling myself that the car is perfect as it is with stainless exhaust 4 inches all the way from dump pipes, boost controller, turbo time that all came with the car...I've gone the pretty much the whole haul and got after market turbos, dump pipes, ECU, injectors etc...bar opening the engine (will happen some time I'm sure) and never looked back....you will get that bug too when you know there's more power to be had.
Good luck and happy driving!
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
