i had my car locked the other day but with the windows down (force of habit to lock the car) and realised that i had forgoten something so i reached in and unlocked the door grabbed my stuff and all of a sudden the horn started blarring at me. scared the bejesus out of me. has anybody come across this before in one of there cars. the importer that i got the car of didnt even realise it had an alarm. i have found a little switch on the d/s kick panel that turns of the flashing led on the dash but i havent gotten around to testing if it has anything to do with the actual alarm.
https://www.sau.com.au/forums/topic/213332-factory-upgraded-alarm/
Has anyone else got the 'NISSAN SECURITY' arial/reciever unit that sits in front of the rear view mirror. I have and i dont know what its purpose it?
Not sure if this is related or not (dont want to hijack your thread)
Hmm yes I do, I thought it was a GPS antenna for my xanavi unit? Either that or something for the Toyota Electronic Toll Controller unit that's been installed...
This little jigger is the antenna for the remote starter. It flashes when the alarm is armed. If you don't have the factory remote or the compliancer fitted an immobiliser it is practically useless except for looking pretty.
Dave, the Factory GPS antenna sits under the dash just in front of the clock. If you had the ETC toll collector unit, you would know as it is pretty obvious.
See here: http://www.skylinesaustralia.com/forums/Da...=remote+starter for more info on remote starter/alarms
Is it true that the Mongoose M80G will function in this way ie. off the Nissan key remote?
Not in my case - I've got the Nissan factory remote key, but I leave it at home and just use the copy I had cut, as it saves me from carrying around the bulky key AND the remote for the alarm.
I think the issue is that the Mongoose uses a rolling code remote, but the factory key doesn't.
Thanks :devil: Yeah I have the ETC toll collector unit, it's a big box taped to the side of the centre console, and when you push buttons on it it says things to you in a female Japanese voice...
Thanks :thumbsup: Yeah I have the ETC toll collector unit, it's a big box taped to the side of the centre console, and when you push buttons on it it says things to you in a female Japanese voice...
uh huh "Insert your ETC card please". Pretty easy to remove. they normally patch it into your cig lighter power.
ahh I wondered what it was she was saying lol
Not patched to ciggie lighter for me though, was a whole massive loom in there with about 10 metres of cable, cable tied up, with 3 wires, one of which was earth, and a whole custom short loom with a false plastic plug in the end that went nowhere... I'll try to get a pic of it all its crazy
Edited by DaveB
  • 10 months later...
sorry to bring up an old tread but i just bought a S2 stagea and its got the thing infront of the mirror and its got a retro looking remote thing as well.. i'll post a pic when i get home.. its got start/stop - check and alarm set on the unit. can't get it too start though, the dash lights come on but go off straight away.
yeah got the same things, cept mine is on what looks like mini mobile phone.
have you got a turbo timer installed ?
cause once i had my tubo timer installed, i can no longer use the remote start. but now if i push check it would tell me that the engine is off, temp inside the car and if its locked or not.
now with the turbo timer installed i push CHECK it will tell me that but the mirror's will fold out , the stereo will come on and the lights on the dash will come on also, then the turbo timer will switch on for 30seconds and everything will shut down.
so basically my factory alarm key from nissan is useless as it only locks and activates the alarm. and some times it doesnt de-activate and im left in a very messed up situation at shopping centers !! so its in no use anymore, just using the key with lock/unlock on it now.
hope that helps to your question :S
here are some photos of the remote unit and the reciever.. i played around with the remote and i can't get it to do much at all.. it beeps and the lights come on but thats about it. when you press the start button it beeps then the dash lights come on for about 1 sec then go off again. p.s i don't have a turbo timer installed
wow that looks different.
mine is the same setup with the buttons but i have a lcd screen on mine . . . . i once started my car from about 250meters away. i was on a hill though in my truck on a cold day. thought what the hell, got to my car engine was warm, had the heat on in the morning so it came on also, aswell as my seat warmers, bloody good idea. only thing is, when i open the door it shuts down. . . like a theft thing i guess
i have that remote and the thing behind the rear view mirror. but mine does nothing, i think during compliance the power was cut to it. there are some weird boxes under the steering wheel and some funny wiring thats been cut off
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
    • The only high-power RB I've personally seen go pop after running for all of an hour on a dyno was built by B2R, while being remotely tuned by B2R. The only wastegates I've ever had leak like a sieve, return, still leak, return and get shipped back the wrong ones were from Turbosmart. The only final drive that I've ever purchased that were unusable, twice... were from Speedtek. The only seat mounts that I've ever purchased that placed the seats in the door frame were from Crank Motorsport. The only poorly designed parts that I had the manufacturer confirm should have been designed as per what I mentioned were from GKTech. The only ECU I've had firmware updates consistently break things are Haltech. The only catch can I've purchased that didn't fit in its advertised spot was from ATP. So forth and so on... Moral of the story, doesn't matter where it's from. Do your research beforehand and stick with products and companies you've trusted in the past.    @joshuaho96 If you want it done right, do it yourself.
    • Something coarse-ish. 180 is good.
    • I was surprised to see all the quick Jack models at the same prices on there. But yeah, grabbing one at 20% off would be great.
