:P After a bit of driving around last night, my accelerator pedal seemed to be a bit 'loose feeling' under my right foot. I thought it may have been the actual plastic part of the pedal itself (that you step on). So, pulled over to inspect using the light on my camera phone, and the WHOLE accelerator stalk assembly was loose as; metal bracket and all (spring and cable in tact though). So, still driveable, but heaps loose. Basically felt like a bolt/screws had come off underneath the carpet and lining, and the accelerator mount was moving around freely and unfastened to the chassis.
Took a few bits apart this evening around the pedals, and noticed the mount was originally spot welded... Spot welds have snapped apart!
Has anyone had this problem before?
Obviously, a simple solution would be to mig weld around the bracket onto the chassis. But a mig aint something i have easy access to...
So i was thinking, maybe 2 tech screws through the bottom, and 2 through the top of the mounting plate, into the chassis. Should be pretty simple.
Only thing i'm worried about: is there anything behind that part of the chassis (that i'm going to screw into) to look out for?
Cheers
Luc
https://www.sau.com.au/forums/topic/213337-accelerator-pedal-mount/
dont think its THAT simple to re-spot weld it on though.
Thought it may have been something that was done at the early stages of assembling the car in the factory by Nissan. (ie - working with a very bare shell of the car)
Edited by Luciano_GTST
Good point GeeTR.
But what i imply about it not being that simple > (going back to my school metal work days here) spot welding requires contact at both outer surfaces of the pieces of metal, right?
Drivers side foot well aint exactly an easy place to get to, to spot weld (by making the contact inside, AND outside of the car)... without removing components of the car to make it accessible (one would think...)
So for an easy and reliable fix; im thinking a bit of sikaflex just to adhesively mount it in its position, and 4 tech screws after, straight into the chassis.
What concerns me as i first mentioned is if its safe to do this! / ie - is there anything on the outside of the footwell to be careful of if i drill in tech screws
Yah, when i was thinking "spot weld" i meant a few beads with a TIG / MIG, not actually a proper electrical articulated spot welder.
My issue with the tek screws, is that if they work loose, you'll be left with these nasty wizard sleeve holes in your firewall.
whats the big deal, just weld'er up. correct Nissan by doubling the spot welds or if you have access to a TIG or a MIG setup with small enough wire you could even do a few stitch welds. Dont go for rivets, thoes will have their days numbered right fron the start where a good weld of any sort will last aslong as the metal its fuseing.
I'm not sure why you think ally rivets will hold when welds didn't?
Im not sure why you think rivets wont hold it when spot welds didnt?
Its held on tight as with the rivets... If you smack the shit out of the bracket with a hammer it still probably wont come undone.
As stated in early posts:- Spot welding this area is a c*&^ of a job. It is likely that this particular bracket would have been spot welded to the chassis at the very early stages of the cars assembly.
i dont have access to a MIG or TIG setup - I wouldnt have even bothered asking on here if i had those readily available. They are piss easy to use, and would do a brilliant job re fastening this bracket without a doubt.
  • 8 months later...
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
