Yeah kgf = kilograms of force.
1 kgf = 10Newtons.
It is the plate pre-load.
I set my Nismo diff to the middle setting & there are more clunks than a clunk convention - although clunkage is dependent on the clutch plate size, number and to a lesser degree the diff ramp angle.
  • Replies 44
lol, the ol sneaky edit while I was posting trick! not sure if they are right but they should be if you found it in one of my other posts. the difference i believe is the preload.
haha sorry mate. I found the pt# for the R200 in the Nismo online catalogue. I don't want the thing clunking around sharp corners as it's still used on the street more than the track, so i'll go for the 8kgf version.
Cheers Guys
  • 5 weeks later...
Hey guys, just an update on my Nismo GT Pro 1.5way...
been in the car a few weeks now and I just changed the oil over to Redline 80-140W Gear oil... has reaaaally smoothed the diff up. Before it used to really clunk and bang and feel like the arse end of the car was going to fall out.. I was going to start dosing the diff with separate friction modifier just to see but instead changed the oil out altogether. Unfortunately I can't say what was in there to begin with - the guy who fitted and setup my diff did not use the Nismo oil it came with and put in 'what he recommended'. But the point is that the choice of oil can and does affect how 'streetable' the diff is. Mine now still skips the outside tyre on the pavement on tight turns, but without all the other crash/bang/fkin-thump from the back.. I reckon if I put a little friction modifier in there now, I could further smooth it up - but as mine is more for track than street - I'm happy where it is. Just enough to show me its still locking, and smooth enough not to piss me off on the street.
So just a heads up. If you do get a harsh diff - try oil or friction modifier to smooth it up a bit - it does help.
  • 4 weeks later...
What do you guys think about the Carbonetic/ATS (same company) Carbon LSD? They are really popular with the 350z(Fairlady Z) and now starting to catch on with the Supras and Silvias. Anyone test one on any year GTR?
    • So, good news and bad news Bad news first: The intake plenum is lost in the mail apparently, I haven't paid for it yet, and MX5 Mania are still chasing it up, farking 'Merica postal service  Good news: Any retune will be free if and when it turns up,  I'm still keen for them to throw it on The car goes noticeably better, with only the typical initial take off thingie from a choppy cam and manual transmission, but giving it just a little more RPM than before gives it a smooth take off (and hour or so of peak hour traffic sorted that little skill out) Car made around 145kwatw & 225Nm (Intake may get me to 150kw, maybe....馃ぃ) Weirdly, 145kwatw is the same max power that my standard 2015 WRX STI made a few years ago The cam really comes alive from around 3.5k and keeps making power and holds it flatish all the way to 7k, whereas before torque would drop hard around at 4.5k Drive home was sadly in peak hour, although I did get a little clean air here and there to wind out 1st and 2nd a little bit, and whilst the gains aren't anything for the "boosted boys" to be impressed at, the thing is a blast to drive The sound in the vid is poor, as it is in a undercover yard at work, but, outside, in the wild, it sounds awesomeballs to my ears with all the choppyness I consider it money very well spent for the outcome  Cam specs for reference (Basically the biggest you can fit with stock pistons) 20250417_171807.mp4   LOL, I don't think I will ever grow up
    • Swap the injectors around and see what happens. If the misfire follows the injectors then that's a signal, if it doesn't it's probably not the injectors.
    • R33 with RB26 seems to go off of learned voltage for idle. Seemed like whatever the baseline voltage was once ECU first gains power will be the idle voltage. With ignition on unplug/replugging the TPS would relearn the idle TPS voltage.
    • Have you confirmed the 2 pin coolant temp sensor on the motor is working properly? I've had a very similar issue when I forgot to plug mine back in many years ago.
    • Ok interesting i guess ill wait till using a manual gauge before making assumptions.
