hey guys im new here and new to skylines. i've owned 4 commodores over the past few years and sick of em and wanting something different. now im quite comfortable checking out holdens as i know what to look for etc but im completely stumped on skylines. i'm selling my two vr's and im after a R32 or R33 turbo'd 5 speed. just after general things to look at mechanically especially in higher km cars, cosmetically{rust spots} etc. im not after any spectacular, just something in fairly good nick which i can modify to my tastes. thx for the help
https://www.sau.com.au/forums/topic/213353-new-to-imports/
Just off the top of my head
Check...
Speedo, all Japanese cars came with a 180km speedo unless factory specified = R34 GTR N1's and up (from memory)
With 180 km speedo its more likely the K's are believable or the best you can rely on anyway.
Listen out for any noises in engine / turbos / diff / gearbox, listen to the car to see if it sounds healthy
Look at the gauges to make sure they are all working.
All the lights in the dash are lit.
Brakes, make sure the disk are not warped and brake pads
Flaky paint on inlet plenum = was driven hard and the heat has taken off the paint.
Check liquids = Oil / Brake / Clutch / Radiator / Power steering
Check the spark plug gaps, only way to tell if the car had a boost controller or not. Usually the gap is Wider if its been boosted and with after-market spark plugs.
Give the car a rev to see how smooth it goes and then give it a quick high rev to see how well it reacts and then check the rpm on idle to see if it drops out.
Test drive the car to see its performance.
Everything should be in mechanical working order!
Bring a mechanic with you!
Interior...
Wear on seats, front and rear / doors / gear shift knob / hand brake / carpets / and all panels
air vents to make sure its not broken or a boost gauge shoved in it
Exterior...
Check Panels for rust / any accident history / paint
keep in mind you are buying a car which are 2nd hand but hopefully to the very good condition and things are bound to be changed anytime soon if not later. Keep and eye on turbos / brakes / diff / clutch...
Unless the car is FACTORY STOCK, one owner with service history books, service every 5000ks and timing belt changed at 100 000km (at least if not earlier) and not a single modification.
If you buy a later model = new car but still check everything.
There is a tonne of stuff, just PM me if you want anything in specific.
Cya round!
Edited by (00)SKYLINE(00)
https://www.sau.com.au/forums/topic/213353-new-to-imports/#findComment-3768560
http://www.skylinesaustralia.com/forums/bu...e-f-t35129.html
^ this will deff help you!!
Im selling my r33 gtst. However in sydney. If you keen let me know :D
http://www.skylinesaustralia.com/forums/R3...05#entry3655305
Edited by siddr20
https://www.sau.com.au/forums/topic/213353-new-to-imports/#findComment-3774269
    • To be fair passengers who aren't silly and have been in proper fast cars have often been pretty impressed once you hit 4th gear
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
