R34 Gtt Turbo For Sale
Hi all,
Yes, I'm selling my R34.
Year: 12/98
Colour: Black
Km's: 81,000 km
Rego: till 15/08/08
Mods: Intercooler, Cat-back exhaust, Coilover suspension, turbo timer, full alarm system, K&N Air filter
Price: $19,500 neg
Please, no time wasters.
If your genuine in buying, call me on 0416 486 009 anytime. The car is pretty much mickey mouse. Motor is A1 condition.
I'm selling as I now have a company car.. And yes, I never thought I'd say this, but I'm getting over turbos... =(
Let me know if your interested.
I dont check the forum much, so if you have any questions, please msg or call me on the mobile.
FOR PHOTOS, PLEASE VISIT www.carsales.com.au , search under the number plate BAP36X.
Thanks,
James
Edited by Assasin
^^^^pics pls
Its Manual.
I dont know how to post pics up.. I'm sorry.
If you go to NSW events and look at some cruises I've done. You'll see some photos of my car, posted up by other drivers.
Number plate is BAP36X.
Look at the last one to Megalong Valley.
Or go to previous events for more photos.
Thanks,
James
 Share
    • Meh. I "see" a typo above, that should have been "sell".
    • The clutch pedal has a procedure for adjustment. This can only be done after you are 100% sure the system is absolutely free of air bubbles. You must bleed the clutch master cylinder first, then the "separation pipe" which is the clutch damper line, then the operating cylinder as detailed in the service manual. Also, you must fully depress the clutch pedal between shifts. Just because you can't feel it grabbing does not mean the input shaft is truly decoupled from the crank. At high RPM clutch plates are vibrating and moving around, you need to give it the best possible chance of success. On the BCNR33 Nissan revises these adjustment procedures slightly but not by much: I would be careful with trying to play games with these adjustments. As for the Nismo operating cylinder they say a lot of things. In practice the twin plate clutch needs less movement on the clutch fork to disengage because the whole stackup of the flywheel + friction plates + pressure plate is much taller. Personally if you find that the clutch still disengages too high at the top of the travel I would try the Nismo operating cylinder. Make sure to follow the air bleed procedures.
    • Thank you for the links. I’m going to go with the 6pin plug you used. next step is rust treating re painting dash support bar and steering column then the 6pin cradle plug when it arrives in the mail.
    • I don't how much the car makes a difference or whether it is just a question of gearbox and clutch. On mine it's fine. Pull type Nismo coppermix twin (standard, not competition) on the 5 speed in my Stagea. OEM slave cylinder. Bite point is a few cm off the very bottom of the pedal. Clutch pedal all the way down to put in gear, and when heading off at the lights, there's a tiny bit of nothing and then it starts biting. And fully engaged before the pedal is all the way released. There's a bit of play at the top where the pedal does nothing anymore. Are you in Australia @ck_chino? If you are set on using a Nismo slave cylinder I have one new-in-box at home. Ordered it together with the clutch but didn't get it fitted. We can work something out if you want it
    • I am using a pull nismo coppermix twin in an r34 getrag box, had both the standard slave and  then the nismo one. Adjusted pedal to get bite point how I wanted , it is on the higher side, but would fully disengage past half way down.  I also read that the nismo slave won't work but I had no issues with the stroke, might become one later as clutch wears but 2+ years of happy motoring so far.  Take the above as one input only, specially as my setup is a bit unique in that I am using an S15 clutch master , cefiro clutch pedal, custom braided clutch line. Lots of variables at play.
