Which one is best for export?
133 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
  • Replies 148
Yeah, Omar...cereal has been pretty negative in the past. He seemed to be speaking for all of us which i didnt like..so...
Not true.
I, and many other people whom have a lot more experience purchasing cars in Japan than you, offered you sane advice which you chose to completely ignore.
And then you magically arrived at a decision that takes all that advice into account a month later and claim it as your own.
Not true.
*********EDIT*********
Most of them seem to be Automatic, hopefully a manual one will pop up soon.
I saw this auto one go for a bit over 2 million on Wednesday
Anyway a decision has been reached, so let's just worry about getting m3gtr in a car!
Yeah James,I think it only added 100 kg's or thereabouts and its basically the same config. Its just teh hatch they had to sort out... I have to say though that i have a surprise in store.
Nice choice. All that performance in a wagon. It is the sort of car family guys like me love. Will fit the family and the Mountain bike or skis.
I felt bad being the first to select a Mitsubishi on a Nissan forum but it is an exteptional car. Would be the only Mitsubishi I would ever consider owning.
Cheers
Andy
Well, its done.
Finance has been approved and the car is right in my grasp.
You'll see it soon enough...and its not an evo wagon. ;)
Sorry Laurence, beers on me when i bring the car down to see you in 'Saka. :D
Edited by m3gtr
oh, and adam, don't be a weener. if you didn't want people to know about your car and what you are buying you probably shouldn't have started all these threads about it... we want details. and pics. onegaishimasu.
    • Sorry I was being harsh there, but am I wrong? You can buy a M340i easily, and there's loads available second hand. A lot more workshops modifying them as well. How about getting parts for them? Don't get me wrong, I'd love a 400R, even a 4cyl (I looked at a few V36s before buying my shitbox BMW). Sadly Infiniti died in Aus and we're stuck with importing them as niche vehicles. Supply and demand
    • Probably straight swap for an R32 GT-R? lol
    • Yes I think we changed out the transmission fluid as I had a leak last year so we changed out the seals also. Need to check.    I should have said just change from 5th to 4th gear … down shift. There’s a grind.    I have a new clutch X clutch … but as I said all the changes in other gears are fine.
    • Change the transmission fluid. I would try Motorcraft XT-M5-QS if you have it in your area for a reasonable price. Also, double check your clutch is fully disengaging. If you are not pushing the clutch pedal to the floor fully for every shift now is the time to start. Make sure the clutch is fully bled. The damper line requires two distinct bleed points to be purged of air or it will not disengage the clutch properly. If either hydraulic cylinders input or output are losing hydraulic pressure in their seals/leaking you can have problems like this. If you've ruled out everything else then the most likely explanation is the synchros are worn and you need to double clutch the shift or rebuild/replace the transmission. The transfer case is discontinued FYI so you may want to rebuild it while you're in there too. If the chain stretches past spec it can do a ton of damage.
    • You're selling the SS?! How much are you asking on it?
