Which one is best for export?
133 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
  • Replies 148
Yeah, Omar...cereal has been pretty negative in the past. He seemed to be speaking for all of us which i didnt like..so...
Not true.
I, and many other people whom have a lot more experience purchasing cars in Japan than you, offered you sane advice which you chose to completely ignore.
And then you magically arrived at a decision that takes all that advice into account a month later and claim it as your own.
Not true.
*********EDIT*********
Most of them seem to be Automatic, hopefully a manual one will pop up soon.
I saw this auto one go for a bit over 2 million on Wednesday
Anyway a decision has been reached, so let's just worry about getting m3gtr in a car!
Yeah James,I think it only added 100 kg's or thereabouts and its basically the same config. Its just teh hatch they had to sort out... I have to say though that i have a surprise in store.
Nice choice. All that performance in a wagon. It is the sort of car family guys like me love. Will fit the family and the Mountain bike or skis.
I felt bad being the first to select a Mitsubishi on a Nissan forum but it is an exteptional car. Would be the only Mitsubishi I would ever consider owning.
Cheers
Andy
Well, its done.
Finance has been approved and the car is right in my grasp.
You'll see it soon enough...and its not an evo wagon. ;)
Sorry Laurence, beers on me when i bring the car down to see you in 'Saka. :D
Edited by m3gtr
oh, and adam, don't be a weener. if you didn't want people to know about your car and what you are buying you probably shouldn't have started all these threads about it... we want details. and pics. onegaishimasu.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
