guys..!
i have a manual boost controller and a GFB BOV...
and i do NOT know how to fit them, was wondering if anybody out there would want to do it for me in exchange for a couple of brewies or $$$ and if nobody can do that or can be bothered to do it tell me how much it will cost at a workshop?
also, my GT-T has a standard boost gauge, would i have to get one that runs over 1 bar to use the boost controller more efficiently and are there any problems if i use the standard one?
(reason i ask this i think stock i'm running 7psi but i wish to run at around 12psi...)
the BOV apparently has to get welded on to my engine too, it's just the trumpet thing and i don't have an aftermarket cooler SO...
any suggestions out there? for those that don't know me i'm not the most literate person mechanially
all advice will be genuinely appreciated, thank you
Andrew :D
https://www.sau.com.au/forums/topic/213420-bov-and-manual-boost-controller/
hey mate,
I wouldn't go running your car at 12 psi without a bigger intercooler otherwise you could get engine knock which is bad also would suggest getting an aftermarket boost guage as that way you can monitor the boost better than the stock one. Running the car at about 10 psi should be fine and not cause any damage to the engine.
The bov should just bolt up where the stock one goes but not knowing too much about rb25s i wouldn't be able to tell you.
If wou need a hand with anything send me a pm and i can help you out
:D
Matt
just a precaution but if you wind up your boost you should get it on a dyno to check air/fuel ratios. so it is better to get a workshop to do the lot. i use IN TUNE PERFORMANCE. they are in the workshops list below. he charges 88/hr and about 80 bux for a check on the dyno
http://www.skylinesaustralia.com/forums/Co...hr-t191756.html
Edited by Pal
hey guys, thanks for the kind advice...
guy, everything's always easy isn't it? haha so how about that suspension?
i don't think i can live without my suspension man!
umm... matty, i'll send you a pm... i can't afford $88 an hour right now especially for a job like this so i'm sure me and you can work something out...
if anybody else out there has any nice words they'd like to say you're more than welcome to, please do so...
Andrew :D
Suggestion: Get an adaptor if you want to install the bov or use silicone pipe! Backyard welding doesnt look the best and you dont want your r34 to look like sh*t under the hood do you? Be wise and get it done properly the first time!!! Save if you have to!
what do you need done to your suspensions?
if your changing to coilovers or something like that it is really easy job, just need a socket set, a jack and about 1hr of your time (maybe less, maybe more)
but remember if you change any suspension parts you will need a wheel alignment, i changed to a different set of coilovers and ended up with some massive toe out
lol guy is the one that is after suspension...
i have mine in yet i have no f*cking clue what type os setup it is *shakes head* god i'm useless...
alright wel i'm set about getting the BOV and MBC in, i'm also thinking (and hope all you guys out there can help me with this one)...
my car is due for it's major service (100,000km's) so should i save up some $$$ and get the FMIC and get all 3 (FMIC, BOV and MBC) all in at once then tune it at the same time with my major service and has ANYONE got ANY idea as to how much this will cost and how much longer i can drive my car until i SERIOUSLY need to change the stuff for the major service...?!?!
danny at imports101 changed a lot of my stuff around before he sent the car to the pits, only things he said i needed to change was the timing belt and i think that's it, all the filters and coolers and fluids and everything were already done i think around 8,000km's ago...
never mind, any idea how much my mechanical desires will set me back?
rough estimate is okay, will go to danny i think for the major service and fitting of all that stuff
cheers,
Andrew
if someone has a reasonable offer then yeah i'm selling the car...
BUT i'll be doing things slowly if nobody buys yet ie. FMIC, BOV, MBC and also probably different kit + paint and some interior goodies etc.
you guys know how it is, for now though i've had some offers that aren't tempting enough so i might play with the car until i see a cash offer
i'll be ringing a few workshops tomorrow eh
:D
hey also andrew if you wanted to do it yourself or not have to pay a garage to do it my housemate and i would do it for a small fee (only because timing belts are time consuming to change) we live just around the corner of where you saw us the other day. Send me a PM if your interested
    • Thanks everyone for the replies and suggestions. Got the seats out (hoping I could find some existing grommets but no such luck). By tapping and measuring etc. I could figure out where I could drill through if needed. But first I borrowed an inspection camera and managed to go through factory holes in the chassis rail and could see that the captive nut was holding steady which is why it could retighten. So it was indeed a stripped section of thread, so I applied downforce by levering the bolt head with a screwdriver and went slowly back and forth until it came out. Camera helped a lot cos I could monitor that the captive nut was holding tight. Now I just have one very seized main subframe nut to tackle 馃槄
    • BOVs do have a purpose, if you ever log pressure before and after the throttle body, you will see a spike pre throttle on lift off from a WOT condition. Enough to bend throttle blades / damage e-throttle motors or simple assist in blowing off cooler pipes. FWIW, the above on really applies to those running at least 2 bar of boost. OP shouldn't have an issue, on the other hand, here are some videos of my shit box over a decade ago with some succulent dose with the airbox on and off. That shit box is unrecognisable these days 馃珷
    • I've tried all different combinations of BOVs/ no BOV and stock bypass valves over the years, on gear changes the stock bypass valve seems to get the car back on boost quicker because in part the turbos wheel speed isn't being slowed down by reversion, although they have issues holding boost much over the stock setting. Most aftermarket BOVs you can adjust the spring, tighter will make it open later and close sooner, but in my experience it'll cause a bit of flutter at low load/rpm anyway. I've also got some input into this whole no bov causing turbo wear, never had an issue on any on my turbos HOWEVER, I got my R33 GTST with 200k kms on it, with from what I can see still has the original turbo, no lateral shaft play but has about 4-5mm of play in and out which to me seems like a worn thrust bearing from years (100-150k kms?) of turbo flutter running no bov, so maybe there is some truth to it in the long run. But that'll never stop me loving the Stutututu while I have the car.   OP just wants to know if he can run a atmo vented BOV with no major issues and the answer is YES, plenty of people do it, there's no harm in installing it and seeing how it runs before spending $$$ on an aftermarket ecu, last time I bought a Nistune it was $2400 for install and a tune , unsure of todays prices but you get me. Crazy money to spend just to fix the minor inconvenience of stalling that can be overcome by letting the revs come down to near idle before putting the clutch in or a little bit of throttle to avoid it. You're better off leaving the ecu and tune for after a bigger turbo/injectors have been installed to take full advantage of the tune and get your moneys worth.   Let OP have his Whoosh sound without trying to break his bank haha
    • I see you missed the rest of the conversation where they have benefits, but nothing to do with avoiding breaking turbos, which is what the aftermarket BOV made all the fan boys, tuners, and modders believe was the only purpose for them...
    • But they do so for the other reasons to have a compressor bypass. It's in the name.
