Hey guys, after my water pump started leaking i went and bought a new pump and thought id put it in myself, as it didn't look that hard to do. I stripped everything to the crankshaft pulley, took all the belts off without touching the cams so the timing wasn't going to be touched. Everything was fine, replaced the water pump without problems and put everything back the way i took it off.
So when i started the car, it seemed to be fine, idled well and everything was normal, until i took it out for a drive...it felt so sluggish in every gear, its as if the power was stripped off me! It sounded fine though, no knocking or pinging, just had no power.
I run a safcII and my usual readings with knk sensor is 30 or so with full boost, when i ran it yesterday, it read over 220. Whats going on, could it be the timing? Im clueless to this situation, any ideas on what i would have done wrong. What could i do to fix it? Any suggestions would be much appreciated.. :D
Cheers,
Steve.
your right in saying that it will only go on one way. but if the half moon shape bit/pin on the end of the camshaft is shapped off it will go on anyway. but if the pin was stiill there you should be right. what about the position of the cas bolts in the slots. are they about half way, even a bit to the right in the slot. thats about the spot your after. i think its best you get a timing light on it anyway just to make sure.
Edited by QWK32
yea apperently i missed a tooth when i was putting the timing belt back on. I just got the cas timed with the belts current position, its got my power back but its not quite 100%. Need to get it tuned again.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
    • Did this ever go further ? Would love some updated info
