Actually i was at Elsternwick Audi looking/drooling over the R8 with my son, and telling him about how Mr P1 will/should have one soon. Not 5 minutes later Mr P1 rang.... cut forward a few hours later, and my son (and his dad :) ) has his first ride in a Massa QP. :thumbsup:
I know all about things nor going to plan…..
Tuesday I went out to a customers site for a Preventative maintenance on a machine. Easy enough. Took very little time to complete, until I powered it back up again. Critical disk read error. Spoke with the customer and arranged to fit a new drive on Wednesday. No problems, left home @ 7am, got there about 10am. Damn traffic and road works. This just so happened to be the day of the bad winds, etc.
Got home around 4pm and got a call from another site in Heidelberg saying that their instrument had a drive failure also. So I went back to work, battled through peak hour traffic with rain, wind and drivers who have forgotten to drive, to fix the instrument. Disk replaced and all appeared to be well. Until I got home at 9pm. Phone rang again, the same customer, saying that the heaters were not coming up to temperature. The damn state files were currupt. So Out I went again and fixed this problem.
I finally got home again at around 12am, and was looking forward to sleep. But guess what…… I couldn't sleep.
Apple make servers? I lol'd at that one.
As for you guys that keep banging on about "IT Nerds", don't hate us because we are smarter and earn more money. Next time you sit down to post a reply on this site just remember, if it wasn't for us you'd still be sending chain letters and hiring your porn from Blockbuster you dirty haters :P
Oh, I remember the days.. Eagerly waiting beside the letter box, hoping that the postman would bring me the latest bunch of letters from "The Wasteland".
post-46113-1207541152.png +1
doesnt really relate but its still funny :D
haha. I like that one. Hence why i've never purchased an iMac. Always the Mac Towers. I have both platforms at home, use them both for different things.
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
