can those who helped put the Vic SAU MAS stand together pm me some details on what they did and I want to ask if that banner with the R34 on is one your guys or borrowed as The WA guys would like to borrow it from the owner (will pay freight to and from WA) for the Western Saloon in October.
thanks for any help
Troy
https://www.sau.com.au/forums/topic/21346-mas-request/
Jamezilla your PM in full so i'll wack my questions in here please pm me
Hi James
The Vic guys said your the man to talk to. The WA ladz are going to enter the Western Saloon in October and we would like to pick your brain for ideas o how you guys setup for MAS.
We have been alotted space for 6 cars inside, and unlimited space outside. We intend to have a race/garage theme along with SAU. We have heaps of track and driver training and drag day footage of our guys which will be showing either on TV's or a projector screen, and we loved your guys PS2 idea so we are going to do that to.
Stickers, we have source that provides very cheap so there not a problem. We also loved the Blue shirts you guys wore, most WA clubs have black tops so if you could hook us up with a source of the shirts that would be sweet.
I believe you are also the owner of that R34 banner? If possible we would like to borrow it for the show (we will pay freight to and from perth) if thats possible, but we totally understand if you are against the idea.
So basically any other ideas or tips you have that could help us would be greatly appreciated.
Troy
https://www.sau.com.au/forums/topic/21346-mas-request/#findComment-451316
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
    • A bit late but A disk S13P fit over stock R32 GTR brakes, usually A disk front, O disk rear works.
