I am wanting to take the weathershield off dat is on both the passengers window and drivers windowaround the top you kno wat i mean =P, bt anyway i WAS going to do it today bt had a look around it and it seems az if i did take it off there would be a gap where the weathershield was. Sorry if its a bit of a noobish question bt after all i still am a noob :D , so yeah basically has any1 taken theirs of b4? if so how? would be thankful heaps :P
cheers in advance :D
Alex
  Alex G said:
I am wanting to take the weathershield off dat is on both the passengers window and drivers windowaround the top you kno wat i mean =P, bt anyway i WAS going to do it today bt had a look around it and it seems az if i did take it off there would be a gap where the weathershield was. Sorry if its a bit of a noobish question bt after all i still am a noob :) , so yeah basically has any1 taken theirs of b4? if so how? would be thankful heaps :teehee:
cheers in advance :)
Alex
Just rip it off. Its glued on with a pretty strong double sided tape. There r a couple of clips along the way so just watch out for them. Hard part was getting the remaining glue off. I used a plastic scraper(one i used to do sum plastering of the wall with) u can get em cheap from Bunnings. Also had to use sum `Goo off' or similar glue disolving product(also from Bunnings) to remove the reamining glue.
Only thing is the Goo Off left the rubber seal around the door a lil on the matt side. The ones around the quarter window is a gloss black n the one around my door is now a matt black. I think the Goo off kinda dissolve the surface of the rubber a lil. Car looks way better without the shields but up close the rubber seal doesn't look as appealing but its a minor cosmetic thing, depends how fussy u r with ur car.
true, thanx
i have heard tho that rain seeps down and into the actual car if u remove the weathershield, is this true or not? after hearing a couple stories i might nt take it off and ill just tint it black so it goes kinda better with the car than this crappy brownish colour...lol
yeah rip em off i did that to mine. then after you do you might have this sticky, or rubber stuff stuck still. i took my time taknig mine off so i got it all off, just be careful when you pull them out the rubber trim is bound to cmoe out of place a little bit but easy fix
  Alex G said:
true, thanx
Nuh no issues with rain seeping in. The weather shield is not factory std so rain shouldnt be seeping in. Who drives with their window down when its rainin anyway? lol...
yeah might give it a go dis w/e, bt ive looked at mine and it seems if i did take the weathershield off the rubber trim around it will like have a gap between the actual rubber trim and the roof, can u then jus push in the rubber trim in then so the gap wont be there? if ya kno wat i mean, sorry if i keep asking i just wanna make 100% sure i get it right the first time and properly at dat, oh yea good point at bout the windows down lol would be a strange sight...
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day
    • While I was waiting for the new parts to come in for the charge pipe and radiator I decided to do some turbo modification. The drive pressure (exhaust backpressure) was a lot higher that I thought it should be. For 32lbs of boost drive was 55lbs. The turbine housing is a 1.10AR and my turbo builder has suggested to go to a 1.25AR. To test if a larger AR would do anything to reduce drive pressure AND not spend any money I decided to hog out the divider in my current housing. I removed it from the inlet and the whole way through the housing.  After reassembly and testing it doesn't look like this modification did anything for reducing drive pressure or requiring more fuel (making more power). Oh well, it was worth a shot. We'll get some data at the track if it makes it past the 60ft. I also machined a $7 shift knob off Amazon to fit my Stillway shifter since I didn't like the Stillway shift knob. Next on the list was the radiator replacement and fabrication of a new intercooler tube that had no silicon coupler. No pictures of this - I was short on time each night after work to get this done and didn't stop to take pictures.  Next was to get the clutch disks out and replaced. Previously when installing the dogbox I had ordered a set of the same sintered iron disks I had been running because I switched to the 26-spline input shaft. I thought it was odd that they didn't have any markings or brand name on them like all my old disks had but installed them anyway. At the track I could not get the clutch to lock up using my normal strategies. After two track nights I reached out to the clutch manufacturer and ask their thoughts. They said they had to switch the material out because they were having trouble getting the original material and that this new material would not take to being slipped very well.  So out with the first set of 26-spline disks and in with the correct material 26-spline disks. While I had the trans out I added an inspection/service hole. I've wanted one of these for a while. Now I can have a look at things and change the front cover shimming when needed (clutch wear). I hustled and got the clutch change done in a few hours on a Saturday. Hopped in the car and drove home. On the way home I did a 1-3 pull. When shifting from 2nd to 3rd the core plug in the back of the cylinder head popped out and dumped all the coolant. Thankfully I was only 30 seconds from home and coasted it there. Datalog showed nothing unusual and 2.5psi of coolant pressure. That plug has been in there since 1992 but I guess it worked its way out. Pulled the trans AGAIN and replaced the plug, JB welded it in, and made a brace. Also deleted the head drain I had added in during the bearing issue fiasco.  I am currently changing my boost control plumbing to make it cleaner. After that is done I'll make another attempt at getting past the 60.
    • Are you 100% sure this isn't tune related?
    • 140-150 across the board. At this point hoping the grounding harness fixes it. My grounds are all tied to the chassis and none to the battery. For SR and KA that’s never been a problem for me but had a few other guys here and Reddit who told me RB really like a very solid ground setup tied to the battery so going to try that next, I’m stumped if that doesn’t do it. Never had a car have spark and fuel and not fire off before. Only thing I can think is the spark is intermittent/weak because of grounds nothing else really makes sense at this point
    • I am having close to the same issue. Can you help me with what wire you grounded to get your pump to trigger?
