ok so i need big cams + head shims
heres my set up
Rb30 rb26 head
greddy t78 turbo
greddy intake manifold
Now please help me find the best cams . I already have 272/10.8, I dont feel its big enough
Next thing
head shims
I have rb26 head with tomei type b head kit
if I run tomei 280/10.8 what size shims do I need??
help me
thx
https://www.sau.com.au/forums/topic/213490-cam-shaft-head-shim-help/
heres my set up
Rb30 rb26 head
greddy t78 turbo
Next thing
head shims
help me
thx
the cams you have are plenty big enough.
the shims are determined by the clearance from the base circle of the camshaft to the valve bucket. Its something that has to be determined by measurement. They may not need changing either...bolt the cam in and measure the clearance to see.
heres my set up
Rb30 rb26 head
greddy t78 turbo
Next thing
head shims
help me
thx
You don't want to put anything bigger then 272 on a t78 as the duration wouldn't be correct with that turbo. it's fullboost is 5500-6000rpm!!!
    • My crystal ball says that when they replaced the pads, they didn't replace all of the brake hardware (could be a missing shim, pin, spring, etc).  Finding a low dust pad should be very easy. Have a google for things like, low dust / soft pad compound / easy on rotors. Your dust primarily comes from the rotors getting eaten up by the pads.
    • I think old mate is going to continue to hold out for awhile at that price
    • OBD1 is a catch-all term for pre-OBD2 which could have basically any connector design and protocol. I really don't understand this attitude against using data logging for issues that can be multi-causal and subtle. A no-start situation or something like that sure the scan tool does nothing but if it runs like shit it can often be a sensor issue. When a friend of mine reliably had issues with his N54 not able to stay running eventually I narrowed down the issue to a faulty fuel pressure sensor. Only way I could do that was a scan tool to look at the fuel rail pressure and see shadow codes for fuel pressure. Then check against a pressure gauge. Is reflexively firing up the data logger probably a bad habit? I guess, it can encourage people to not listen/observe but on these old OBD1 cars just taking a log really doesn't do anything by itself. You still have to synthesize everything you know and think about what it all means.
    • https://www.carsales.com.au/cars/details/1999-nissan-skyline-gt-r-v-spec-bnr34-manual-4wd/OAG-AD-24005316   i reckon some former Skyline owners are wishing they held out a little longer before selling up?
    • Yeah saw that video on YouTube. But he got a R grade (repaired) high mileage model and proudly advertised the fact it was super cheap and no doubt with issues. I wouldn't be going the cheap and nasty route.
