Facts:
A few months ago (4ish) I had a crash some guy jump on the breaks at a green and I slide in to them my car went to the panel beaters and they done an awesome job. Any ways the engine bay light (orange) comes on now and I took it in to ultra tune and he said it is not my spark plugs or coil packs it is a part that is going to put me back. Around 900 dollars "Cam Sensor". Now I will like to know does this part happen to be in the car. Or are they trying to blow smoke the guy said let me buy the part 4 you and we will fit it at a price. The part at $900.00 and fitting $XXX I do not know he did not say.
My bosses at work said take it to Nissan because ultra tune is good 4 small jobs (I cleaned it up) due to my car as an import Nissan wants to dyno it for 3 hours @ $110.00 an hour before they do work on it. So it will be $330.00 then what ever the parts and labour will be.
Problem:
Before
When the light comes on it sounds like a sick wrx and the engine bay rumbles
Now
The light comes on and it does not really sound like a wrx she is starting to smooth out and sound like normal.
Please help me out.
Questions:
A) Is there a cam sensor?
B) Is this problem worth 2/3 advices.
C) Will Nissan be worth taken it to at this price?
D) Should I try to find a import place that deals with skylines.
E) Because she was off will the fuel was just sitting in her will this be making a problem and all i have to do is just drive her and flush her out?
Thank you for your time in reading this topic
Edited by DiNoBoNeS
https://www.sau.com.au/forums/topic/213500-what-to-do/
Mate im not sure what the problem is, but i would suggest going to an import workshop and get them to look at it and quote it. a few:
Hyperdrive
C-Red
X-Speed (will be pricy)
There are plenty more in the "consolidated workshop thread". Check it out and find someone local to you. All the workshops in that thread are reputable.
(Ultratune + Imports = No clue) :)
https://www.sau.com.au/forums/topic/213500-what-to-do/#findComment-3771638
go to Hyperdrive, and talk to Andrew, was there before and having a talk and he seems to know his stuff..
and I dont think Nissan would be a good place to go first up, try some of the workshops around first and leave Nissan till last.
just my thoughts
https://www.sau.com.au/forums/topic/213500-what-to-do/#findComment-3771655
obviously if it sounds like a WRX then one or more of the cylinders arent firing.
Possible causes...dead sprak plug from pinging, old age, over fuelling etc, coil pack dead....swap for another one, or closed injector (probably not)
Dont ever waste your time at these nuffy chain mechanics. If you cant do the job yourself then im sure some good friend off the forums can come around and have a look for you. THen if it stumps the more seasoned backyard mechanics then take it to the reputable big guys who wont spin some crap.
FYI, yes there is a cam sensor. It sits on the end of your exhaust cam and looks like a cup face down. If thats the problem then the car might start to compressor surge, will drive ok, then suddenly have flat spots or just generally be impossible to drive. I wouldnt think that would be the problem in a 34.
If it is then theyre available a lot cheaper than that second hand, all though that price he gave you is pretty much spot on from Nissan.
https://www.sau.com.au/forums/topic/213500-what-to-do/#findComment-3771755
thanks people i did not have a clue on where to take it i will give them a call thanks 4 all the help. all so ultra tune (i am not bagging them out) just i do not know what there like on imports there more of four cylinder cars and holden and fords
https://www.sau.com.au/forums/topic/213500-what-to-do/#findComment-3771890
take it to the workshop ron
on a better note guess it's time to live up to ur number plates name hey?:devil:
https://www.sau.com.au/forums/topic/213500-what-to-do/#findComment-3772039
FYI - the cam sensor is the big round silver thing hanging off the front of your engine right at the top, and without actually hearing the engine its too hard to say what the problem is, but if the CAS stuffs up, it may be sending some pretty weird info to the ecu OR it might have nothing to do with it. Do you have (or know anyone with) access to a consult cable? Cause this would tell you the problem straight away.
https://www.sau.com.au/forums/topic/213500-what-to-do/#findComment-3772162
Mine also sounded like a rex for a good few months, upgraded coils n plugs. Put new AFM in it. No help.
Ended up ginnin around with all the electrical plugs n what not. turns out the contacts were dirty or something in one of em causing a cylinder to not fire at all.
Gave it a spray with the air compressor and cleaned it out. plugged back in and run like a charm : D
https://www.sau.com.au/forums/topic/213500-what-to-do/#findComment-3772416
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
