i want to share my first time experience with every body who wants to get a rb30 fitting with rb26 head into a bnr32
hope my taste floats ur boat.
actually i have the longest going project thread on GTRCanada.com, hope i can do that here as well :)
this project been going to almost 2 years march 2006.
got the car then 6 days later it blew up so i decided to do something i'll never regret doing so i went with the rb30 since not many ppl have done it here in canada.
with building a rb30/26 here is a list of problems i came across
-4wd adapter makes the holes to the tranny from engine block dont match
-cheap 4wd adapter requires the use of external oil pick up
-block is taller, which means turbo sticks out too high, hitting shock tower,
-block is taller, which means rad hose don't fit
-block is taller, which means all IC pipes + down pipe has to be extended.
-have to use RB30 timing belt
-have to extend timing belt plastic cover
-i have greddy intake manifold + taller block height, making the manifold hit against the clutch master cylinder on bnr32 with clutch boosters
Engine
-RB30DET
-Greddy T78 single turbo
-Greddy intake manifold
-Greddy Exhaust manifold (braced)
-ACL forged pistons (ceramic coated)
-SPOOL forged rods
-balanced / polished crank
-N1 oil pump
-Keep Labs custom external oil pick up
-Keep Labs custom external oil return (turbo/head)
-OEM water pump
-Greddy racing BOV
-Greddy 50mm waste gate
-Electric fans
-F-win Rad
-ARC oil cooler (grill mounted)
-Greddy oil cooler (Vmounted)
-Removed ABS, Custom brake lines (hidden)
-Trust 100mm intercooler
-Areomotive FPR
-HKS 280L fuel pump X2
-Nismo 275L fuel pump x1
-Powerflow fuel filter (x2)
-Black Stainless lines
-Sard surge tank + Stainless fittings
-Earles stainless lines
-Grex 272 cams
-SARD 1000CC injectors
-ARC Ti cooling plate
-Trust coolant breather tank
-Custom Ti exhaust (KTS)
-ACL bearings
-ARP Bolts
-Tomei Type B Head Kit
-Tomei head shim kit 1.7mm
-Tomei sump baffle
-Nismo engine mounts
-Greddy catch can
-Custom rad overflow tank
-Racing Battery relocated to behind passenger seat
-Gates RB30 timing belt
-Tomei 1.8mm 87”metal head gasket
-custom anodized earls fittings
-Greddy 100mm intercooler pipes
-HKS turbo bell mouth
-Greddy over size pully kit
-ATI crank dampener
-Billion rad hose
-Split fire coil pack
-Custom 4wd sump adapter plate
-Billion Power Steering fluids cooler
DriveTrain
-6spd trust dog box H pattern
-Push Pulled conversion
-OS Giken triple plate clutch
-Push to pull type Conversion kit
-Essential strengthen clutch piston kit
-Cusco front 1.5 way type MZ lsd
-Tomei T-trax rear 2 way lsd
-Nismo Steering rack bushing
-TEC Metal Steering rod spacer
Interior
-KTS 7pt Rollcage (custom padding)
-recarpeted rear floors
-Bride Zeta3 (L) bucket (driver)
-Bride Gias Carbon Kevlar (passenger)
-AC unit relocated to Glove box
-HKS Boost controller
-Defi Link Water temp. guage
-Defi Link Boost guage
-Defi Link oil Temp guage
-Defi Link oil Press guage
-Defi Link Ex temp
-Defi VSD-X
-Defi 80mm Tach 11000rpm (white face)
-Defi Link indicator II
-Custom carbon center glove box
-Toggles switches / led lamp
-Power FC Controller
-Carbon Kevlar cluster
Exterior
-Greddy rear skirts
-Nismo f-bumper
-Custom Carbon bumper Lip
-Custom Carbom N1 side skirts
-Custom Carbon hood lip
-Custom Carbon N1 ducts
-Custom Made Angel Eye N1 headlights
-D-Max Carbon Hood
-Custom LED rear License plate lamps
-Sard GT Spec M Fuji 1700mm wing stands 1210mm (Carbon Kevlar)
-Custom CNC Wing Stands
-Grams Light 57s-pro 19X10 +0
-Blitz I-Spark headlight blinker
Brakes / Suspension
-Cusco Tension rods
-Cusco rear camber arms
-KTS front camber arms
-VTTR Front 6pot 2pc rotor racing brakes
-VTTR rear 6pot Racing brakes
-HKS Hyper Max coilovers
-Metal sub frame spacer
-Cusco front & rear sway bar
-Custom over size Endlinks
-KTS lug nuts
-ALL Nismo hard bushings through out
-Seem welded suspension tower
here are some pictures
i hope to get the car running by the end of jan 08
cusco front diff
custom brake lines, all hidden
oil pan modded to fit rb30
block with head studs arp
ATI ATI ATI ATI ATI ATI ATI
hks turbo mouth
my seats bride gias carbon kevlar
greddy t78 33d
sparkly engine bay
sparkly trunk
black stainless lines
fuel system stuff ( getting them anodize polish silver )
welded shock tower
ported head
1000cc sard injectors
vttr brakes
pink engine cover
ti exhaust
Edited by felixy69
https://www.sau.com.au/forums/topic/213503-my-rb3026-bnr32-build-project-horny/
  • Replies 110
UPDATES
the motor is IN !
but more problems
for those who think RB30 is a direct bolt on..u are wrongin, as the rb30 block being taller, with my Larger greddy intake manifold, the back it of HITs the clutch master cyclinder, we end up moving the master cyclinder higher up
for those who think RB30 is a direct bolt on..u are wrong again, as the rb30 4wd requires sump plate, the sway bar came really really close to the sump. tho the sway bar isn't connected to the shocks yet so we won't know what will happen under final adjestment.
and it hits the NEW brake lines we made so we had to make new brake lines the 3rd time.
enjoy the pictures
i'll take more with a real camera once the tranny is in today !!!
pics taken with cherry picker still has it's tension, wthout it the engine will tilt back hitting the above listed items.
i really hope when the tranny is in. these problems will not happen !
so i had another problem today
it was when i bolt the tranny to the engine it would engage the triple plate clutch,
turns out i have the wrong release bearing sleeve, what i have was the oem 16mm, i needed to 14mm one made for triple plate clutch,
well this was a japan part and no one in canada have it so i decided to make my own
here are the pictures
also shorten the essential privot
shorten the push rod on the slave
hope it can go back together tomorrow
also on another hand, i got rid of the small rubber bushing on the tranny mount, in replace i weled 2 steel plates, may be it can stiffen the tranny part.
also done was
due to the fact that rb30 make the engine taller, and the need of sump adapter to hold the 4wd sump, besides the fact that i have to make new holes on the bottom of the tranny
i also have the cut apart the housing so that this shaft won't hit
GREAT !
Another Problem.....are you excited ??
well this one is a small problem and is that the upper rad hose don't fit due to the extra block height :thumbsup:
greddy large intercooler pipes is too short
greddy Large side pulley kit is too big and will not be compatible with ATI damper
so these are for sale if anyone wants
more comming soon :)
hey look
first my water hose dont fit due to the extra block height
now my turbo is too big !!
check it out....its not even bolted down to the manifold yet and it's already hitting the shock tower
and here is a New battery try "keep lab special" and relocated from back of the passenger seat to the trunk.
everything is still in the mock up stage...going to get it plated and anodize next week
so more progress today
made the apexi EVC into the test pipe
remember my turbo clearence issue ?
well instead of bangging out the shock tower, we modifided the exhaust manifold so it's more to the left
as you can see there are more clearence to the shock tower and less to the engine cover.
i also told u before that the water tube on the rb30 block is higher so the exhaust manifold needed to be ground inorder for it to fit
then we decided instead of having the waste gate vent back into the exhaust, like how it was before, we are going to externaly dump it, so we cut + patch the down pipe, later i am going to warp it with black heat warp
some random pictures
my clutch master (from EK9)
twin fuel filters
the guys working hard
some artistic stuff
aeromotive fpr
others
some pic of my fit
ok here is the end of the week update !
wow i have a spoon part on my nissan gtr.
it is a spoon low temp thermal switch
FAL fan for Supra
with custom mount to the rad welded
custom mounted fuse box
heat wrap wires
clutch lines finished
Ti exhaust mounted
this is something tricky
because the engine is taller, all the pipes needs to be longer, and because i have a greddy manifold, the intake pipe needs to be 4" instead of 3"
so we cut and weld + extended the intake pipe from the IC, also made it 4"-3"
some hose clamps
I NEED TO SELL MY GREDDY 272/10.8CAMS ! $450CND...i got BIGGER !
here u go
rb30 dib stick tube was remove and replaced by the oem rb26 one. as in the picture you will see the height difference between the two, so with using rb26 dip stick, i have to use rb26 tube.
-oil pick up finially finished
random shots with 4wd adapter bolted to the block
thx more to come !
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
