  • Replies 110
Xmas 2008 update !!!
after spending another $2500......i got another RB30 rebuild kit. from spool imports from australia.
very good guy to work with !! and he's very helpful.
here are the detail pic of the cf items i got..i must say....using carbon kevlar (yellow) is very hard to do cuz u can see the blemish very easy....like un even weaves
A picture tells a thousand words
  • 2 months later...
here's news
oil pump blew up on the dyno @ idunno what rpm but the highest we had was 7000rpm but the end result was bend rods, need new bearings..etc..
rebuild again...
sorry to bring up the sour memories but did u run a oil pump crank collar with your n1 oil pump?
do u know the reason why this oil pump let go? ive spoken to 3 mechanics who actually vouch for the n1 oil pump 'if' the crank collar is fitted
  • 5 months later...
Do you have a web site or the company name of where you got the carbon kevlar overlay done? It looks insane
Don't know where you are located but if you look at them parts it is simply carbon wrap (original plastic is under). can do it yourself. carbon sheet is about $70 a square meter then you need some resin and patience.
Or you can buy the fibreglass sheeting that has the same weave as carbon and dye it black then use it :P (about $7 a square meter)
it looks cool but unless you are going to make a mould and make a part completely out of carbon there is no actual benefit to be had apart from the looks...
Edited by GT-RZ
