  • Replies 110
Xmas 2008 update !!!
after spending another $2500......i got another RB30 rebuild kit. from spool imports from australia.
very good guy to work with !! and he's very helpful.
here are the detail pic of the cf items i got..i must say....using carbon kevlar (yellow) is very hard to do cuz u can see the blemish very easy....like un even weaves
A picture tells a thousand words
  • 2 months later...
here's news
oil pump blew up on the dyno @ idunno what rpm but the highest we had was 7000rpm but the end result was bend rods, need new bearings..etc..
rebuild again...
sorry to bring up the sour memories but did u run a oil pump crank collar with your n1 oil pump?
do u know the reason why this oil pump let go? ive spoken to 3 mechanics who actually vouch for the n1 oil pump 'if' the crank collar is fitted
  • 5 months later...
Do you have a web site or the company name of where you got the carbon kevlar overlay done? It looks insane
Don't know where you are located but if you look at them parts it is simply carbon wrap (original plastic is under). can do it yourself. carbon sheet is about $70 a square meter then you need some resin and patience.
Or you can buy the fibreglass sheeting that has the same weave as carbon and dye it black then use it :P (about $7 a square meter)
it looks cool but unless you are going to make a mould and make a part completely out of carbon there is no actual benefit to be had apart from the looks...
Edited by GT-RZ
    • Thanks for that.... If only I could do something once and be happy with that, like some people do....
    • I had no transmission at all so I managed to find a big box manual gearbox from an R34 GTT for an insanely good price in EU. I converted it to push type which cost more than the transmission almost, with parts from Amayama! These engines are very strong and can put out decent power with a properly sized turbo. You can save on money from parts like pistons and rods, and invest those in the transmission and other parts. I suggest you join the RB20 Enthusiasts facebook group, plenty of info and almost daily posts there about 20DE/DET/Neo+T builds. (I hope I'm not breaking any forum rules by mentioning third party platforms, just trying to help the buddy out)
    • Yeah, having tried all of those methods including BBQ+recipro/hacksaw, I ended up buying a bush press kit under $150 that works well, like this: https://www.ebay.com.au/itm/355967727167?mkcid=16&mkevt=1&mkrid=705-154756-20017-0&ssspo=sfmmuhxgqhm&sssrc=2047675&ssuid=dJvnaZ11TB-&widget_ver=artemis&media=COPY It basically has a range of pushers and cups with threaded rods between to press out a range of large bushes. The problem with any sawing solution is minimising damage to the subframe side, although it probably needs a quick sand afterwards no matter what solution you try due to damage
    • Hi. Thanks for the answer. I do not have instagram 😄 I too considering turbo the RB20DE NEO 🙂 But i think i upgrade the gearbox first or at least buy new.
    • Just pulled the passenger apart so got a good idea, also the side bracket that pivots the top half is completely cooked.. how I don’t know.. haha and paid $400 also included a photo of the passenger seat! She is mint
