  • Replies 110
Great work with your build. Its refreshing to see someone sharing their assembly process with such detail.
Now when someone has RB26/30 buld questions they can just come to your thread instead of being flamed for not using the search button (which produces more BS than real useful information).
Do you have a purpose in mind for the car? Drag, street, track or all of the above?
Hi, just wondering if you have felt the clutch yet, im looking at having to remove the clutch booster to fit my plenum. Also why did you go for the integra master cylinder instead of the original one?Was it due to the fact the stocker doesn't have provision for a fork?
the clutch feels fine..i don't feel a different without the booster
thanks ....
i will keep the updates going ..when i am back in canada..
i am currently traveling around tokyo and HK !
  • 3 weeks later...
more updates !
it's finally looking lik a car now!
with fuel system completed !!!
starting from the back
fuel lines protector guard !
fuel line holder
at the front
dash completed ! glued the back together !
heat sheild for turbo and down pipe
hand made wrap!
HKS to4Z turbo bell mouth machined to fit with my T78 greddy turbo
since the engine is 3inches taller...we made this angle down so i can use my billion rad hose instead of getting soemthing else
polished PS tank
so more work done @ Keep Performance Lab today ~
i must say these guys are so Good with Wires !!!
again keeping it clean is always on the top of the minds. so organizing the wires were very important as it is easier to work on as well as it looks alot nicer.
here are some pictures from today
back of the kill switch mounted where the rear wiper used to be
attention to details
Keep Performance lab even got the Bolts on a OLD HKS coilover GOLD PLATED
my external oil pickup as well as both the external head oil drain and turbo oil drain (had to reuse some old fittings as i don't have time to get new one anodize gold)
    • If you want to do a single throttle body conversion easily, you won't need to pull anything apart. Take the linkage from your throttle off the linkage controlling the ITBs. Now open the ITBs wide open, and lock the linkages in said position. Now add a single throttle body onto the front of your inlet plenum. No it's not ideal for the last nth of a kw, but it'll be a lot better than what you're already trying to do...   PS, ITBs can be so damn hard to tune from, because roughly 20% movement in a throttle body equates to a change in roughly 80% of its flow (Hence power). When you add up the flow limitations of those small throttle bodys, it is a LOT higher than that of a single large throttle. Hence, TPS is very very sensitive with them, and you do a LOT of work with sensor fusion, and some Maths behind the scenes to make those blends nice, and be smooth.
    • Yep, when Haltech purchased Adaptronic, and all of the Adaptronic staff, including Andy went with it, it took Haltech to the next level. Haltech wanted Adaptronic as they wanted things like Andy's fuel models, and some other IP, AND they wanted Andy too as he is brilliant! Andy has spoken about the incompatibilities between the old 1500 stuff vs Nexxus, and it totally makes sense. It's not JUST software that is different, there is huge changes in the underlying hardware too. It's why Haltech has had soooo many changes in the last couple of years, in terms of Hardware, and Software, and why it has become so damn Amazing. Why do you think guys like Rob Dahm with his quad rotor, went from running Adaptronic's to running Haltechs? Andy. Pretty much, Haltech these days, is Adaptronic, but with more funds behind it, and more staff, and hence Andy's visions, and visions of other people that he helps shape their great visions, into amazing new products. All the new Nexxus gear, whole new software for it, new and better dashboards, the apps that will run on headunits and NOT be slow to respond! I understand people being burnt in the past, but if you're ragging on a company, about products and issues from many years ago, it's more a reflection on yourself, not looking or keeping up with new stuff. In which case, those people should be going back to PowerFC and Nistunes as the ECU's to rave on about...
    • Right, but I thought the problem has been for a while now that even if you know manifold pressure + throttle position you still have non-linearity and aliasing issues vs actual engine load? One way I can see things simplifying is going DBW, then all air going into the engine is represented by the throttle position. As opposed to a random bimetallic strip vaguely linked to engine temperature opening and closing a shutter or some random power steering air valve suddenly allowing a bunch of bypass air. But the same throttle position/RPM at ~atmospheric MAP in different gears is not guaranteed to be same engine load? Honestly, ITBs are of such dubious value IMO. I don't know why these things are hyped up so much. The main benefit as far as I can tell is you reduce the likelihood of cross-cylinder EGR scavenging with significant cam overlap at idle. I would absolutely run speed density and be done with it if not for this fairly esoteric control problem.
    • Hah dont worry, my adult brain has this conversation every single day. Dont waste your money, invest more of it into shares, pay down the mortgage. Then the bedtime insta doom scrolling begins and after being bombarded with gtr's my mind is set: im definitely getting one! I have the current model mx5 as the weekender, but i just miss my boost and literally like your username, the sututu's that come with it. I remember with my 2nd supra, as it had twins and vvti, they used to spool real early, like 1,500rpm so you could just be a spooly boy all day long. Some people say they get over it after a while, not me tho.
    • If you need to refinance your mortgage and reset the loan terms back to 30 years and cash out on your equity for "investment" purposes *cough* car parts, I can help 😊
