That goes to my BOV and charcol can on mine. From the look of it, it has broken off at some stage and the rough end put on, which is fine but the 12yr old hose could be farked as well, which is why it broke in the first place. If you bend the hose sharply does it show fine cracks? If not cut it off that damaged bit neatly and push on i use tiny zipties to be sure it stays.
the hose seems pretty pliable but I think its been cut once before. There is a stand-off on the intake that looks like it would hold this hose clear but there isn't enough slack to get it up there. probably worth getting it replaced.
Is the other end connected? If it is, I'd just push it on. If if works its way off again, then grab some cable ties to hold it on. Everyone has some! Again, if that doesnt work, then get a small hose clamp. It doesnt look like it would carry too much pressure, so I dont think it would be anything to worry about. Looks like it has been replaced once before, judging by the unstraight cut
    • For a daily just run Akebono ceramic pads. That's what they're optimized for. Obviously don't try to run it on track or anything like that.
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
