Hi all,
I need some questions answered.
My R33 series 1 has a wire come from the flooring and plugs into the bottom of my drivers and passenger side seats. Then another wire comes from there and hangs loosely with nothing connected. What is this for? Airbag? Should the wire just being sitting there loosely?
Thanks
https://www.sau.com.au/forums/topic/21354-wiring-in-front-seats/
Thanks,
But I found the problem is that when they removed the original seat belts, the wires were connected to where the belt connects. This would send a signal to the dash saying your seat belt is on or off. Just a safety feature.
So the new povo belts they put in would not have this feature and so the wires cannot be connected.
hey guys,
just a quick answer to shed some light on whether they can be used for anything else.... i wanted to hook some under seat neons up to them which would have been controlled by a switch on the dash, but before buying the neons i tested the currency of the plugs with a multimeter and found that there was less then 0.20volts going through, therefore there was not even 1volt going through, so i gave upon the idea of using them for neons..... i'm not saying i'm right, as it could just be my car, so can anyone else here test them as well to see whether u get the same results, as i really wanted to use them for some neons, perfect spot and all :P,
many thanks (interested to hear results now!!!!)
yeah, as stated above, I was told in my R32, that they are for the seat belt light. The chairs sense if someone is sitting in them ,and if the belt isnt on, the light on dash will flash.
For compliance the seatbelts are swapped as the jap ones dont have ADR approval. The seatbelt, and the seat belt thingy that it plugs into are swapped. Mybelts even have a different anchor bolt into the chassis near the door....
As this is only a small function, it wouldnt require much voltage.
Will
  • 5 weeks later...
Do all Skylines have air bags?
My series 1 GTST doesn't have an air bag at all (dash or wheel) and it has those wires under the seats!!! maybe rule thos options out!!
Has anyone looked at there new seat belts for front seats!! had my interior removed recentl;y and those seat belt moun ts done look very safe!!!
it's like a single bolt through thin body steel, going to a metal plate that the belt bolts onto!! any one else seen this!!!???
The wires are there in the R32's for the electric seat belt retainers - you may notice sometimes that the seat belt will not automatically retract or have any force on it wanting it to retract. As soon as you undo the belt from the buckle, it automatically retracts. This was as a comfort feature, I thought it was rather stupid personally and disconnected it, thus always having tension from the belt on my chest.
    • Have you tried another indicator stalk? Sometimes these go bad and cause issues.
    • They're so beautiful 😍
    • Early last week, I became concerned that the car was feeling....slow. Most of my driving is commuting to/from work and there are few opportunities to get up it and convincingly make boost/power. It drives in vacuum almost all the time. But when you do occasionally get an opportunity, and.... it takes a little longer to start making power, and then there's not as much as you'd expect, and then you run out of road anyway and have to bottle out - it can be hard to be convinced that there's something wrong. But by the end of the week I was pretty convinced. Made an effort to get a decent test run. Took bloody forever to come up on boost and when it did it would only make about 50 kPa of pressure. There was no black smoke, no noise of a boost or exhaust leak, no evidence anywhere of an intercooler hose clamp being sloppy enough to let air escape. So.... not that sort of problem. Brainstorming led to thinking that the boost controller's solenoid might have failed in some way. No active boost control would just give wastegate pressure, which I was more or less getting, and the laggy behaviour could just be "normal" shitty boost response from an uncontrolled highflow. But a little extra 3rd party brainstorming led to the thought that the actuator circlip might have jumped off leaving me with a bluetooth wastegate. So, on Friday, off comes the stock heatshield (which is an annoying enough job on its own) to reveal - yup. WG is wide open. And.... it won't come back. It is jammed in the dump. Put the rod back on with a new circlip and tried driving it to get it hot in the hope that the capture was from thermal effects having been blown into the dump when hot and since cooled. Nope. Won't move, even with screwdriver mediated force when hot. Ran out of time to play. Came back to it yesterday. Unbolted the dump. Was lying under it with the dump jammed up against my guts undoing the bottom 2 bolts. Got them most of the way out and gave the dump a serious heave. It didn't noticeably move, but there was a satisfying "plink" noise from up to. Shuffle out and sure enough, gate is now closed. Nevermind that there was still the better part of an hour after that required to put it all back together. f**ken cars.
    • For your application, where you'll be at that 1/2" size or perhaps larger, yeah, excellent. Although not if you need a tight bending radius anywhere, because the corrugated stuff is not anywhere near as flexible as rubber/teflon cored stuff. But for turbo oil lines? No. Too big. They just don't do the corro stuff down at the ~1/4" ID size that you'd want, and if they did the OD of it would probably be a bit too fat for fitting it into the tight spaces available. I use hoses like that all the time for fuel gases (LPG, NG) and liquid fuels (HFO, diesels, waste oils). When we did the London Olympic cauldron, with the 204 individual burners on it, we had miles of the stuff (although a lot of that was teflon core). A bunch of that crap is still cluttering up the workshop, more than 12 years later!
    • Would something like this be an option  https://processhose.com/products/configurable-metal-hoses/1-2-in-t316-stainless-steel-annular-corrugated-configurable-flexible-metal-hose-assembly-with-ends-t304-single-braid-masterflex-af5550.html I'm looking at this for replacing the OEM EGR when installing a aftermarket intake plenum
