Guys,
I have a rb20 running a 2535 running 14psi using a bleedvalve (yes I know, but my elec boost controller died recently...)
It makes full boost at 5k rpm
any idea's what could be the problem? Surely the 2535 cant be this laggy
Yes i did abit fo a search...
Cant find any boost leaks, found a few suspect connections and fixed them up, advanced the timing slightly.
Any help would be awesome, as its not very drivable :devil:
Cheers,
Dan :(
Edited by works 510
https://www.sau.com.au/forums/topic/213541-rb20-gt2535-not-responsive/
Supporting mods.
gtr or 040 pump, i have to check it
3" exh with GKtech dump and hks front pipe, cat is std for now.
evo3 intercooler and home made piping
awaiting to install gtr injectors
blitz pod
Ill get a tune asap :devil:
Yep must be pinging its head off at 14psi and injectors are probably maxing out too
Get the GTR injectors installed and get it on a dyno - REMAP/PIGGYBACK/STANDALONE but either way you will see improvements
Put the boost down before you blow something :thumbsup:
tune isnt gonna bring the turbo on song any quicker... exhaust flow governs how quickly ur turbo comes onto boost..
first thing u should look @ is exhaust flow properties. check ur cat, make sure nothings block and ur exhaust is as free flowing as possible.. check wastegate operation as thats what controls the speed of the turbine. if its opening a lil too early and slow enough, it will make ur turbo laggier than it should be. spring tension is something to check for on the gate.
2ndly cams with more duration and lift will bring the turbo onto song quicker, but ull need supporting mods.
If its an aftermarket manifold, wrap it up. heat = energy. the more heat u can keep inside the exhaust the more energy will be exerted to the turbine wheel at a higher velocity hence reduce lag.
check ur intake for restriction.. try blowing through a kfc straw or sucking.. not very good for flow compared to something bigger like a maccas straw.
a tune will only make what u have a lil more drivable.. but it wont bring ur turbo on full song any quicker.
START WITH THE WASTEGATE SPRING TENSION FIRST
^^ Macca's straw FTW!
PS: Iv seen increased ignition timing changes raise fullboost point by 300rpm.
Dato 1600 FTW!!!
I spent my youth droooooling over 1600's...
thats all.... *cough*
A solenoid type boost controller made a world of difference for me. By the way, that much boost through that turbo WILL melt your pistons if you're only running stock injectors, please turn the boost down for now!
The hks2535 isn't the most responsive thing on a rb20...in fact...just about any turbo except for the stocker won't be responsive...i know because i've got a 2535 on a rb20...however...yours seems alot worse...
The guys here have basically covered all your bases...restrictions in your system would be first thing...and then after getting the proper support mods a tune will go a long way to improving driveability once you dial some timing in...if you cannot afford engine management and a tune now then suck it up and drive it the way it is...do not run at at 14psi...turn it down to 10psi and run it till you can afford it...mind you it will run like a POS till then...
HKS turbos usually come with an adjustable actuator which you could possibly shorten to bring on slightly better response...mind you max boost will also rise so be careful...and when the time comes for the tune...running higher max boost will also improve boost resposne down low...i have attached my dyno graph from my recent tune...it should give you an idea of what boost response vs rpm you should be expecting...thats at 19psi though so boost response is abit better but its still gutless down low...
Thank for the help guys :yes:
Ill turn the boost down for now and have a look at the actuator.
As for restrictions in the exh, the only one I have is a stock cat (been gutted tho)and funds are minimal at the moment
The rest of the system is either brand new (catback was made a few weeks ago) or in good nick.
I had a play with the timing last nite, didnt really bring the boost on earlier, but it seemed to gain abit of power
Intercooler piping? Its not the best and long, could this make it worse?
Sorry for the questions, ive been playing with weber powered nissans all of my life :thumbsup:
it will be the hks actuator not setup right
I think there was one with the kit softy bought off me
they need yeaps of pre load to get them setup right
setup soft they will still run 14psi just very late in the rpm like what your getting dont expect much under 3,500rpm even setup right though
you should be needing to use two hands to put the rod onto the clip
    • PRICE  : $1400 LOCATION   : NSW Central Coast FIT  :  All Nissan 350Z type Z33 and Infinity G35 Coupe. See delivery note. Hi, brand new, unused, still in the box.  ($1850.00 is what i paid ) My bad luck !!! I thought my right front  Bilstein was cactus so i bought the ST 's to replace all.  Turns out the right front is fine ( loose mounting after service  by a well known importer of Bilsteins ) So im selling the ST's. They are made by KW ( no intro needed ) . Iam on the Central Coast and im willing to meet up in Sydney metro, within reason and Newcastle.
    • Yep, yeah would need to do the flywheel although the 6 bolt NA clutch can handle a 20de if just wants to replace the stocker.
    • No it's fine. Heat sleeve is a thing. With oil running through it it is unlikely. Engine off heat soak can be a thing though. There is no way that you have a leak through the hose. That has pressure behind it and any small hole will turn into a large one in very short order. It is so much more likely to be leaking from the connection.
    • Really? That's piss weak. I didn't know they hobbled the shitboxen that badly. OK. So probs need to buy a flywheel too. But that's not too bad.
    • Hi all. I already posted some newbie-ish questions here and there but this will be my first "big" post. Last summer I went and fulfilled a kind of childhood wish, because I just thought I needed this experience in my life no matter what. The car I bought is a mildly modded 1995 BCNR33 Vspec. It was repainted to a metallic orange color all around and it had all windows reseated. Not so well done black respray in the trunk and a metallic black in the engine bay. From outside it looks very nice except for a minor paint error on the roof and the rear spats needing new adhesive tape. The inside is pretty clean and no broken plastics, missing or faded buttons. Even the adjustable mirrors and trunk antenna work like a charm. Despite a moderately long list of issues I don't (yet) regret buying this car. Most mechanical problems are just due to age, like worn rubbers here and there. The underside sadly has lots of corrosion, especially to the back. It looks like it either has been driven in the winter for a while or it lived near the saltwater in Japan, the rust is nothing terrible but it'll require to be looked after. Mostly panel gaps and all the mounted components underneath are a bit crusty, but I don't think anywhere has progressed so badly that there's going to be holes. Front right jacking rail is crushed and needs some care so it doesn't develop into a rust crater at some point. Worst part is definitely the strut towers. I thought they looked fine but after taking off the strut bar I noticed that it actually started bulging up on the passenger side. Probably would have passed on the car or negotiated down by some thousand Euros more if I had noticed this before buying, but here we are. Trunk area also has signs that there was a water leak to the interior once but nothing too crazy, I guess lots of Skylines had this at some point. As for the list of (known) issues, I'll try to make this compact. I hope the coloring is self explanatory. Mechanical: -Various busted or soon-to-be busted rubber bushings and ball joints. Will replace ball joints with OEM or better and bushings with polyurethane where possible. -Shaking steering wheel at above 80kph -downshift from 5th to 4th is a bit crunchy unless I rev-match, might just try to renew the shifter assembly, but it's not a priority issue -tailshaft centre bearing could use a replacement, is it worth going 1-piece tailshaft as it doesn't look too fresh all around? Chassis: -underbody corrosion on many spots and in hollow spaces, needs to be treated -corrosion on many bolts, hoses, lines, suspension components, subframes, will be treated when replacing of the bushings is needed as time goes on -strut tower top panels and some of the surrounding panels are rusty, so needs fixing. Will look into doing this with a buddy in the winter, otherwise bite the bullet and pay a professional -driver side door is misaligned to the body and needs to go a slight bit more inwards -both door windows are misaligned and have an airgap where the window meets the door at the B pillar -The Aerocatch latches for the bonnet have locks but no keys, need new keys. -driver side door window is kind of gritty and could use a polish -damaged jacking rails and front frame rails, from people lifting the car the wrong way, might have this fixed by a bodyshop Electrical: -Nismo tachometer is just bouncing and displaying nonsense, supposedly worked fine when the stock ECU was still in the car -An old Greddy boost controller sits on the dash which will be removed as it servers no purpose anymore. -a led segment rpm gauge is on the steering column, will probably also be (re-)moved once the Nismo tacho is working correctly -there was an attempt to make the sound system better by the previous owner but it was just inducing noise all the time, ripped out the amp and filters in the back, no music for now -trunk antenna goes up as long as the radio is on regardless of the mode, I want it to only rise if I choose Radio specifically or per switch -3rd brake light is a bit dimmer than the taillights but everything was converted to LEDs so mabye now it just seems dimmer? -reverse light flickers, have to test if that behavior changes when I fiddle with the gear stick. Hope I can get around changing the switch. -Left side taillight, blinker section has minor water intake and is humid after washing. Other side has a hole in it, probably for that exact reason. I'll probably reseal them entirely and plug the holes. Engine: -minor coolant drips on one or the other hose -rear turbo leaks oil onto the exhaust making the car essentially undriveable due to fire hazard -Oil filter relocation kit has an oil drip at the Dash lines, will probably make a new connection there and tighten real good and pray -throttle body assembly is slightly stuck for the first throttle pedal input after sitting for a while I'm always open to suggestions and advice from more experienced people, I'm sure half of this list is easily dealt with and just requires some time and effort to sort out properly. Once I have some proper pictures of the car I will post some in this thread, I just have to remember to take some more once I get the chance to. Will post updates when I have news on anything, I want to try to keep this thread as kind of a logbook as well. Ultimately my goal for this car is to just enjoy it. An engine rebuild is probably going to happen sometime as well, because it is old after all. It will never be fully new again, I am just not that rich. But I want it to look good, work well and not rot away while I drive it. I'm probably gonna spend a lot of money on this journey, hopefully not an unreasonable amount.
