Retard the timing down low?!!!
YES.... you can lower spool by retarding the timing down low. This is because the petrol is still igniting when the exhaust valve opens so you get hotter more expanded air comming out the exhaust which helps with spool. But obviously lowers the low end power a bit... depends on what you want really.
I lowered the spool on my old KKR480 by 1000RPM by doing this, but ofcourse its not really good for the turbo as it will run hotter for that brief moment that its in low revs. Also when I did it on my car I set it so that it would only do it if you had over 80% throttle so when daily driving it had good timing.
Go and retard your timing right back as far as possible, I bet the turbo will kick in really quick and probably get it really hot and most likley over boost past what the wastegate is set to. But obviously the car will run like shit....
tuning can make the turbo come on more progressively and wake it up
but i think there is something missing to the puzzle, a tune will certinaly help
but i suspect theres another reason - check the basics
look for pipework leaks, cracked hoses, leaking vac lines etc
screw the actuator to 1 bar... wont even need to run the gay bleed valve then. This well help it ramp up hard for sure (check it on dyno for inj duty - my injectors (standard) were still good for 230rwkw (@ 1.2 bar with standard ecu and HKS fuel cut defender with hks 2530) - although your turbo should make more than mine did...
Yer bleed valve got the arse today.
Played with the actuator adjustment before. Added some pre load its making .9bar, Seems to come on abit harder but still full boost at roughly 5krpm.
I brought the car with a r32 gktech intercooler kit included. I may redo the pipes to suit a31 and put that on. If anyone has seen softy/phil's ceffy they'd know how dodgey the evo setup is :D
I kinda agree partially with you there...a richer denser mixture would help spool the turbo up quicker...however i do not see the benefits of retarding the ignition timing down low as you have mentioned the low end suffers...and by quite a fair bit...
If we are talking about turbo spool alone then yes perhaps retarding the timing might help...but if all we want is just a richer mixture then wouldn't it make more sense to just richen up the mixture down low instead of retarding timing? also...i agree its gonna run hot as retarded timing does make the engine run hot...not a very good thing if you ask me...
I'd personally be more inclined to run as much timing as you can down low without detonation...running the engine as efficiently as possible improves power, torque and response...best case scenario for the engine...and as mentioned before...if his boost response is bad...it probably shows that there are restrictions in his system which should be sorted out first...restrictions plus alot of heat is not a good idea...
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
    • You must be fun at parties.
