Hey,
After removing / reinstalling the radiator my Greddy guage was flashing a warning and not going about 30degrees, turns out one of the wires broke off the temp sensor, about 2mm away from the actual metal part of it, tried soldering and ended up breaking both wires off.
So where can I buy an aftermarket temp sensor?
Are they all the same?
Do I need to import one?
Regards,
Gareth
hang on
which one is broken
the one that gives the signal for the stock guage
or the one that gives the signal for the ecu
they are different sensors
Really?
I thought the one at the bottom of the aftermarket radiator is the stock gauge / ECU. The PowerFC hand controller reads the temperature just fine right now.
There is also a temperature sensor at the top of the radiator, this has caused a gauge inside the car to flash "warning" constantly as its not getting a reading anymore. The gauge in the car is aftermarket, Greddy gauge.
Regards,
Gareth
if it is the standard sensor you are after go to autobarn, burson ect and ask for a tridon one and they will be able to get one off the shelf for you. seeming its an aftermarket rad it might be a different sized sensor take the old one in with you and if it is different one look in the back of the book and there will be a heap of diagrams so you can match it up.
if it's a greddy temp sensor that you need for a warning meter gauge
you will have to import one,
expect to pay about $89 incl delivery.
Ah right, yes its a greddy water temperature gauge and a greddy/trust radiator so that sounds like what I need.
I was hoping they used some kind of interchangeable part, its just 2 wires going to a temperature sensor in the top of the radiator.
The stock one at the bottom of the radiator is fine, the PowerFC can read the temperature without a problem.
Interesting idea, I'm not so sure about going back to Burson's after the last episode with them (gave me the wrong clutch fan about 3 times before they got it right).
But might be a good idea, as long as I can get an exact match.
Found an ebay auction which is selling the gauge with the thermostat, I just want the thermostat though:
http://cgi.ebay.com.au/Greddy-TRUST-Electr...1QQcmdZViewItem
Alright, think I've found one for a decent price:
http://cgi.ebay.com/ebaymotors/ws/eBayISAP...ShippingPayment
Bought for around ~$64 US delivered from the USA, brand new. Relatively cheap I think :cool:
    • Why not? Since mines been built, I've used low boost maybe 5 times.
    • Yeah, so widen your search to any Nissan speedo first, then go wider if needed. I will say though, that there is a better than even chance that what I said first will likely come into play. They quite possibly won't come apart without damage. I tried to disassemble a stepper gauge that I wanted to repair. There was no way that needle was coming off the spindle, and I could not see how the spindle would come out of the mechanism behind. Assembled once, never to be disassembled, was my conclusion. Could be the same on the R34 cluster. Failing that - take the cluster to a workshop that specialises in automotive instrument work. There's usually at least one in every Australian city. They'll either be able to do it for you for small cost, or tell you it can't be done. It might be that "it can't be done" unless you follow some arcane procedure, including trickiness to glue it back together or something, that only experienced techs know.
    • Well, given that I, an engineer, almost never bring out the torque wrench to tighten up chassis bolts, despite fully knowing the theory, and instead rely on feel, which I happen to know is exactly how the majority of mechanics do things, should tell you the level of actual peril that exists from not achieving exactly 88 Nm of torque. How about if I just say then that 88Nm is at the lower end of the correct wheel nut torque range? Everyone knows how to tighten a wheel nut, right? And almost no-one ever brings out the torque wrench for that task
    • Don't be ridiculous. "2-3 ugga duggas or one Oof. You have to use Oof on tie rods because you can't get an ugga dugga on there." Is not helping the guy at all.
    • I have done a lot of research before posting here and on gtruk forum. couldn't find anything. I have my gauges all part except the needle itself. the needle has a extremely small hole in the center, but the shaft going to the needle is extremely small and appears to have nothing to index it either. doesn't seem strong enough to simple pry or pull without damaging something. Already tried the old spoon trick on a extra triple meter I have from a gtt, but no luck. the center cap comes off easily but the hole in the meter face plate aren't big enough to get over the needle itself. figured this would be my best place to find someone who might have actually removed theirs. wonder if there is some type of small pin press tool to push the pin in while pulling the needle base off.
