My 19's were originally a pearl silver colour, but would always look white in photos.
When i painted the car, i powder-coated the rims to "precious steel pearl". Didn't need sandblasting as rims were still in unmarked condition. Payed $120 for all four 19" rims
Before:
After:
blasting is used to both clean off old coatings that may not survive the curing process as well as to etch the surface to improve the adhesion of the coat.
they look great Al, im suprised they didnt strip them first though.
The surface was hand sanded before coating.
Coating has now lasted about 4.5yrs. In that time they have seen multiple track fun days, motokahnas, drags, spirited cruises, etc.; Yes on a couple of occasions i cnbf swapping rims so i done a couple of track fun days with the 19's :D. The coating has not cracked or bubbled, so they have withstood all the punishment.
I have seen other rims powder-coated and some have flaked off, etc. This would be due to poor workmanship and preperation.
I only had to re-coat one rim as i got a little too close to my garage center brick pillar :blink:
they do look sweet
hand sanding is fine if the coating will stand up to the temps for the cure. cant wait to get my new oven setup so i can start doing some rims
where they clear coated aswell?
they do look sweet
My 19's were not clear coated as i wanted the satin finish.
My 17" track rims are clear coated as i wanted to see the difference between satin and gloss.
The gloss makes the "pearl" in the powder coat shine more, but the satin finish is smoother as it obviously has less layers.
dont knwo what you mean by smoother with less layers - you can get satin clears too
got any close ups of the colour?
  • 2 months later...
Can anyone recommend a specialist in Sydney or better still Western Sydney that can do good sanding + powder coating?
And would 'black' powder coat look good on OEM R34 wheels on a R34 GTR that's already pearl black?
And lastly would you paint the wheels satin or gloss? I get the feeling that satin would highlight the car more (- whereas gloss would pull attention away from the car).
Any opinions?
Cheers
Any opinions?
Cheers
Check out Twoogle - r32 GTR with r34 GTR rims in black for how the rims will look. - in latest HPI mag
im hoping to have my new setup done in about a month then i'll be able to help you out with coating the rims :whistling: im near Richmond so not too far from you aswell.
Sorry for the late reply Chris, never received notification of your reply in this thread.
In my experience the clear coat, added on top of the colour powder coat, has more of an orange peel finish.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
