Help Me!! Missing Under Load
Guest r33gtsttrout
I have a problem!! its driving me nuts!! whenever im dropping back to second and flooring it my car seems to have a miss after a second. It lasts bout a second then dissappears.It does it whenever i really give it a bootfull. its mainly stock running 10 psi, and when im giving it to it it pops up to 11 psi for a brief second and this seems to be where it misses. its only starting to do this, and i've always had the boost set at this. yesterday i put new ngk iridium plugs, oil and filter, fuel filter, pod filter, injector cleaner, cleaned afm!!! guess what!! Problem still there!!!!
I've thought of maybe a boost leak, or fuel pump on the way out!! but i'm not sure!! I NEED HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!
https://www.sau.com.au/forums/topic/21356-help-me-missing-under-load/
disconnect the battery and push the brake pedal afew time turn lights on whatever just to drain the resuming power from the system. Then reconnect the battery and the computer should be reset and re learn some sutff. Apparently it should be done after each engine mod so the computer can make the most outta it.
also heard that to reset the ecu you disconnect the battery and leave it disconnected for 24hours and reconnect it but i pressume that using the brake pedal and lights to drain the power out and doing it that way would still reset the ecu and is a heck of alot quicker
    • Ok cool, because I do have some OEM BMW options for light(er) wheels. 17x8.5 M Sport wheels are 11kg and I could put 255's on them. Maybe that's an initial test.
    • So, in the effort of pulling apart airboxes and testing enclosures to see if this aids in MAP loss at WOT I noticed: 1) The ducts up the OEM intercooler holes from the front bar help IAT drastically, whether the pod is shielded from the engine bay by an airbox missing a lid, or an airbox WITH a lid. Plus you get more induction sound without the lid. Having half the airbox (with no lid) acting as a barrier to the headers seems to help. 2) For shits and giggles I checked the TB. This was full pedal travel. This is actually full travel of the TB. Photos aren't perfect, but there was definitely an amount of play in it and it wasn't against the stop. After much swearing and adjusting the pedal, I realised that the cable is actually too long for the skyline pedal travel to fully articulate it. Having the pedal adjusted so WOT was actually hard open on WOT resulted in an idle of 3500rpm. As an aside, this was also the TPS registering at 3.1%. I removed the above to give the pedal enough travel to actually fully open the TB. I now get a satisfying 'thonk' on full open and full closed which you can hear pumping the pedal as it hits the TB stops (with the bonnet open and intake back on). Luckily for me, the screw screws into a raised metal boss under this plastic piece that is now acting as the new throttle stop. I've gained about 20mm (ish) of pedal travel and I can move it maybe a mm or two post open-thonk before it's hard against the stop. After all of this I did a bit of road tuning because a 102MM throttle is sensitive. The difference between holding an 950rpm idle and instantly stalling is about 0.4% of TPS movement. Will that help? I suppose it can't hurt. I set 'closed' point back to where it was, I can definitely feel the extra pedal travel that is needed to actually open the TB fully. But this morning I dropped the car off at Paint Jail again, so who knows when this will re-eventuate out to see if it helps with the top of the dyno hitting a ceiling.
    • Take heart that everyone else seems to have found a way. The OEM S1 indicators do slot in pretty firmly. It may simply be a case of having them sit slightly looser and nobody actually ever noticed this when attempting to remove a indicator from a JSAI bar :p
    • If the original NA ECU has a separate TCU then you are going to need to reroute wires that used to run between the trans and the TCU to the appropriate (1 to 1 equivalent) pins on the ECU. Other than that, it should work. Look up posts by @Kinkstaah on the subject.
    • So the stagea was a series 2 neo det with tiptronic auto. (I have the transmission aswell) and has integrated tcu in the ecu. I'm hoping to use the entire stagea ecu, engine and auto harness.
