I know Speedworks have recently gotten in some great low priced one piece dump and fronts or separate (depending on what you require). Available in stainless or mild steel.
Ive got a mild steel one of these on my car and I cant complain.
They are all the single pipe type (eg: no separate wastegate pipe). You can find Speedworks in Carbon Ct, Ozzy park.
Red17
https://www.sau.com.au/forums/topic/21358-dump-pipes/#findComment-452421
  • 4 weeks later...
i had mine done at Quick fit exhausts in morley, was under $300 for mild steel 1 piece for the r33
i ordered a 1 piece one from batmbl for the 200sx and that was sweet as and cheap as and quickfit had no problems installing it at all, so his option is looking pretty good and he sends it quick smart
https://www.sau.com.au/forums/topic/21358-dump-pipes/#findComment-496359
Originally posted by Strich9ine
is this easy to fit myself ? anything to watch out for ?
it's too easy, but use crc and give it time to seep into the bolts on the turbine housing otherwise you'll be up for fixing those, which can be costly if they can't get to drilling the bolt out without taking the turbo off
Recommendations for a SINGLE dump ? none ofthis dump-front crap!
partitioned dump pipe, maybe with ext venting gate for maximum flow, zero turbulance
https://www.sau.com.au/forums/topic/21358-dump-pipes/#findComment-496682
Yeah, the dump from the WG shouldnt meet the main exhaust, and therefore it shouldnt be a problem. Dont swap back to a single pipe, as that is what u replace it for in the first place - to reduce turbulence.
200zRRR: Go for a dump with seperate WG and main exists, whether its a screamer or not. The pipes shouldnt meet until they get to the front pipe, to reduce turbulence. Good luck finding the right one.
https://www.sau.com.au/forums/topic/21358-dump-pipes/#findComment-497469
My standard one is sitting in the carport about to get thrown in the bin. Looking at the pipe you will notice that the wastegate comes out and meets a wall at the back of the flange. provided you can rectify this and increase the flow diameter, you should have no trouble with a dump which d.n. have a separate screamer pipe - provided you are running a stock turbo.
I have a friend who could use this dump as a template and knock one out for VERY cheap. anyone interested pm me.
my pipe goes in the bin on friday.
https://www.sau.com.au/forums/topic/21358-dump-pipes/#findComment-499598
sorry guys, but it is indeed very hard to exactly match the partition for a stock turbo screamer pipe, this is why most do leak :) the main exhausts gases are leaking through the wastegate pipe it does have a seperator plate but most of them don't sit flush between exhaust outlet and wastegate outlet so this is the reason why mine is leaking, and i am changing it coz it sounds just a tad gay :D
adrian :)
https://www.sau.com.au/forums/topic/21358-dump-pipes/#findComment-502604
As I've said on in this forum several times before, after I fitted a single piped dump and 3" front pipe my boost spoolup dropped from 3500 to 2600rpm, only gained about 10HP peak but the difference on the road with the car spooling up faster is huge. Although there is nothing like a big turbo kicking in and putting you back into the seat like my trusty td06 :D
https://www.sau.com.au/forums/topic/21358-dump-pipes/#findComment-502647
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
    • Don't do what I did, use a 300000km old housing with billet gears. The old pump probably was clearanced with saw dust, Edward Lee's special engine treatment sauce and a good odo wind back. I had oil pressure issues, then replaces pump with new housing, new billet gears and 2x track day later binned a motor due to other oil related issues due to a previous engine builder. Long story short, buy a M2 or 3 or 4 N55/S55/S58 and enjoy life.
    • Yeah. "New pump" does not have to mean "massive pump".
    • Well, can you still get an OEM pump, and by the time you're buying a Nismo/N1 etc, just buy another aftermarket pump. It's better to have the pump able to flow more if its needed, than for your pressure to drop off. At any point in time, you're replacing the oil pump in a rebuild. Aftermarket pumps are likely going to be a better economical choice, and they don't have any negatives, even if they can flow more.   Also, when you're saying "replace the pump gears" are you meaning leave a 25+ year old housing in the engine with unknown wear, and just put new gears in? As that sounds silly to me, especially if you do have that minute amount of wear, that means your new pump gears now have a little bit more clearance beside them, which means, whelp, you may not get to build a lot of oil pressure or make a lot of flow.
    • Right, but if you replace the pump gears + put a spline or sine drive gear on the crank on a Nismo/OEM/N1/etc pump at that point do you really still want more flow/oil pressure? Let's say this is a the aforementioned "keep it simple" build, no more than ~400 kW at the crank.
