bit more of an update....forgot to add this....you will need to machine off about 2mm of the hub.....don't worry it does not affect anything.....but if you don't do it it will rub against the rotor.
I didn't need to do this. R32 GTR 32mm discs. about 1.5mm clearance. drives fine. I will add after removing the olive in the caliper to grab a very fine tooth file to smooth the mating surface of the banjo bolt cooper washer to ensure a good seal.
hmmm....your the second person to say this to me.....Scott said the same thing.......he even has my old R32 rotors. In saying that I had to remove this area on mine and Andy's AR-X.....maybe there is a difference in the offset between the RX and AR-X.
If the Hub Bearings are different it could change the offset...maybe
I will also say, if your brake discs are currently warped to sort them out asap. I think I left mine to long and it has worn my power steering rack to the stage I now get shudder when turning the wheel quickly.
The hub bearings are the same part number....maybe the upright is slightly different! Never had the brakes warped on the front of this car but I do get a shudder on left hand sweepers under power.....reckon its the CV's on the LH shaft or steering rack? Need to get it sorted....or maybe just don't turn left....lol.
Roger that, who knows then.
I checked my rack end play...definately what my issue is. Only happens when I turn right under power or sitting dead still and turning the wheel quickly.
I had the same 2mm disk clearance, ARX must have different front end which would make sense if the strut has 40mm extra travel.
  • 1 month later...
does anybody have the DBA code for standard rear M35 brakes?? the maxima and xtrail dont show rears on the dba website..
thanks
from the DBA website... Perhaps try looking for 350z Touring brakes :)
4000 Series Performance Brake Rotors
Position DBA # IRP$ (AU$) [?] Description Dia. x Thick.(mm)
Rear DBA4574 $275.52 ea 4000 Series Standard Left/right-hand Vented 292 x 16
Front DBA4954 $250.47 ea 4000 Series Standard Left/right-hand Vented 296 x 24
Rear DBA4574SL $325.61 ea 4000 Series Slotted Left-hand Vented 292 x 16
Rear DBA4574SR $325.61 ea 4000 Series Slotted Right-hand Vented 292 x 16
Front DBA4954SL $300.56 ea 4000 Series Slotted Left-hand Vented 296 x 24
Front DBA4954SR $300.56 ea 4000 Series Slotted Right-hand Vented 296 x 24
Rear DBA4574XS $375.71 ea 4000 Series Xs Left/right-hand Vented 292 x 16
Front DBA4954XS $350.66 ea 4000 Series Xs Left/right-hand Vented 296 x 24
Street Series Increased Braking Performance
Rear DBA574 $122.45 ea Street Series Standard Left/right-hand Vented 292 x 16
Front DBA954 $163.69 ea Street Series Standard Left/right-hand Vented 296 x 24
Rear DBA574SL $197.87 ea Street Series Slotted Left-hand Vented 292 x 16
Rear DBA574SR $197.87 ea Street Series Slotted Right-hand Vented 292 x 16
Front DBA954SL $222.92 ea Street Series Slotted Left-hand Vented 296 x 24
Front DBA954SR $222.92 ea Street Series Slotted Right-hand Vented 296 x 24
Rear DBA574X $222.92 ea Street Series Gold Left/right-hand Vented 292 x 16
Front DBA954X $275.52 ea Street Series Gold Left/right-hand Vented 296 x 24
Edited by iamhe77
  • 5 months later...
I'm looking at getting DBA rotors for the wagon.
The existing slotted discs it came with are getting too thin.
They don't like the heat generated slowing the M35 down hills like Stanwell Tops and Kangaroo Valley and keep warping.
Trying to decide between the DBA954X / DBA574X which are their 'Street' Gold cross drilled and the more expensive 4000 series rotors, either slotted or cross drilled.
Is there anything wrong with the cheaper 'Street' brakes, I've come across a few posts where people claim they've heard of some bloke cracking cross drilled brakes, but it seems a bit like an old wives tail.
I don't want to spend money pointlessly, but brakes are the place to go a bit nuts.
Any other good rotor replacements for stock calipers? I've seen the RDA ones on ebay, but I can't find any good info on their full range.
Thanks
They bolt on perfectly, a couple of us have done the conversion.
Are you selling yours? PM me a price if you are.
Need to source me a set of these.
Edited by Paramour
Do you want to find out the hard way? Get slotted but not drilled.
I'm leaning towards the slotted after doing more reading.
This link (provided by GSLRallySport) pretty much describes my problem
http://www.stoptech.com/tech_info/wp_warped_brakedisk.shtml
Save a bit of cash and spend it on pads...
hey buddy....what you say?????
P.S. I know I'm a smart arse!
  • 1 month later...
Having done a fair bit of reading on brakes (zomg theres a search button!) I was just wondering whether slotted rotors and good pads with the standard calipers is a worthwhile upgrade or if the only way forward is a caliper upgrade?
Seems like there are heaps of options, k sport, 350z brembos, akebonos, but I'm curious if theyre worth the premium for a road car...
    • Holy smokes brother. If you get there before me, let me know if that was manageable with a hone. I still haven't done anything with mine and probably won't until I get the car MOT'd later this year so that I have another 2 years to do what ever needs to be done. I am at 86.5 now so at least I have the 0.5mm to go up from where I am, but that means new pistons at the very least. Honestly, might consider a stroker at that point.  Cheers
    • It's the adhesive holding the ceramic wheel to the shaft the fails on 90% of them.
    • Foreign debris, physical shock, boost leak, could be anything honestly. The danger in taking all the timing out of a tune/hitting the R&R corner is that even if the engine doesn't detonate your turbo is taking a lot of abuse from high EGT. Also, even if nothing goes wrong it is a journal bearing that is spinning at 100k RPM on boost. Eventually it goes through enough cold start/pressure cycles to wear it out.
    • I kinda accidentally saw this, and was interested, but It actually seems to replaces the whole center computer, using the existing screen and buttons. AND it may only be for a G37 and not compatible with a Japanese 370. So its not for me, but someone else may be interested to look into it. Its about $680USD. If I am understanding it right, it basically replaces/installs and android pc that integrates with the existing screen. But I could be wrong. https://gromaudio.com/vline/ The video I first saw was the following, with very little and unclear details.     Even if your not interested in the system, the video on their site was pretty comforting in showing how simple the whole centre comes out
    • hfygrte52 what side you looking for? Do you care what color car it's off? Found a white LH side on here: https://skylinespares.com.au/product/nissan-skyline-r33-coupe-rear-tail-light/   Aussie parts place but will ship to USA. Maybe get it before there's a tarrif on 25yo shit box parts
