Recently I performed some intake temperature tests. They are not dead acurate but are atleast an indication of when heat soak is affecting your engine. I used some digital thremometers from jaycar for the tests.
The car: 1993 R33 GTSt, 3" turbo back exhaust, 8psi (stock) boost, stock intercooler, pod filter with cold air partition (95deg neoprene heat shield).
Ambient temperature: 17degC
1st Test: Cruising at 110km/h
Pod = 15deg
AFM = 15deg
Engine Bay = 35deg
2nd Test: Stuck in traffic (45km/h max.) (heat soak had set in)
Pod = 35deg
AFM = 37deg
Engine Bay = 55deg
3rd Test: On boost hill climb and high speeds
Pod = 14deg
AFM = 12deg
Engine Bay = 33deg
4th Test: Heat Soak
After pulling up at a set of lights from cruising at 110km/h, it took 3 minutes to reach full heat soak as shown in the 2nd test. It took 7 minutes of driving at 110km/h again to fully get rid of it.....
5th Test: After idle for 3 mins
Pod = 40deg
AFM = 43deg
Engine Bay = 60deg
https://www.sau.com.au/forums/topic/21359-r33-gtst-intake-temperature-tests/
rb25 - do u have a cold air intake?? e.g. a tube rigged from somewhere front of your car to feed your partition steady supply of cold air? Of course, not much use at idle.
*Very* interesting results, about time somebody got scientific on this :P
Those that take their skyline to the strip should take note. Obviously sitting there idling as you wait to get your run (can be 20mins), gradually moving forward - its just like traffic unfortunately. Even if u regularly turn your engine on and off heat soak is going to set in and its going to effect your times.
A suggestion: Can u at all do plenum temperatures? Obviously you've got some good before intake results, but the most important thing is the actual temps going into your engine..
Interesting results...
Now all u need to do is *borrow* someones carbon fibre bonnet with the vents in it and see how much of a difference it makes (obviously weather and traffic conditions would be hard to keep accurate).
Interesting. The people driving around with pod filters but without partitions should take note of the air temps they are sucking in.
What thermometer model did you use?
I tried to buy thermometers from Jaycar 2 weeks ago to perform similar testing with my own partition (http://www.endusk.com/skyline/caip/caip.html) but the dumbasses couldn't find where in the shop they put them.....
When I get some I will add some notes on the temp differences between using just neoprene and using aluminium + neoprene stuff + sealing rubbers.
I forgot to mention that without a duct forcing air into the partitioned area the heatsoak reduced at 60km/h and above, even in traffic.
predator666: I dont have a duct rigged up to it at the moment. I will do some plenum temps very soon (end of this week/early next week)
Sil8ty: I got the heatshield from Century Foam and Rubber. It's about 8mm thick, sort of like neoprene and has a reflective foil on one side. My partition cost 2 hours of time and 4 dollars.
kjb_r33: I've been informed that the clutch fan on the engine from the factory is excellent in its efficiency and i think that at high engine speeds it pulls alot more fresh air int the engine bay thus making it cooler.
sewid: boxhead has a similar partition (made from metal) and it gets red hot. Metal partitions in my opinion suffer from heat soak and would lengthen the times to get the intake temps down.
I've posted a pic of my setup below. I know its rough, but it seals to the bonnet and the top of the wheel arch and right up to the back of the headlight and it works really well.
I have thought about that as well. Now the aluminium is insulated with foam it gets warm but never hot/red hot/too hot to touch.
To solve the problem of getting the heat out of the aluminium i was thinking of thermal epoxying on some aluminium heatsinks on the cold side.
I dont know if this would worsen the problem of heatsoak however in the long term or increase the effective heatsoak time to beyond average lenght of time spent stopped thereby negating it.... Only way to find out is to experiment.
Or could just remove the headlight and poke the pod out the front :D
    • Bit of an update to this one. Having some issues on the dyno that held us back (boost spiking) and I want to pass some info over you guys and see what you think is wrong with my setup. The current readout on this dyno is 462rwkw on a low reading dyno so keep in mind it is a real world 500rwkw setup on a hub dyno. Don't read into the power figure too much as a sign of the issue. The short and curly of it is: 2.8 Litre Racepace build RB25 NEO N/A Head with VCT (internally standard however ) Borgwarner EFR 8474  Turbosmart 50mm Straight Gate + Mac valve 6Boost Manifold 4" dump to full 4" exhaust (nil restrictions) Wastegate plumbed back in and all angles in the exhaust system are acceptable and not too sharp. GFB SV52 BOV in cooler piping  Turbosmart BOV in EFR Housing   The issue we are having is it comes onto full boost for example at 4000rpm and spikes to 24/25psi, before dropping down to 17psi before slowly rising back up to the target boost of 23psi. It was extremely uncontrollable and the tuner actually had to ramp in boost progrssively with each 1000rpm on each boost setting we selected to try and reduce the amount of spiking. Sometimes we would see a drop of 10psi from the peak at the beginning of the run, to the low, until it took the next 500-1000rpm to stabilise back up to the target boost. The tuner is pretty confident that the straight gate is just a poorly designed product and leaks too much boost upon cracking the gate open and theres no way to fix it other than going to a poppet valve. He's also confient theres no ignition breakdown or floating valves. The fueling is extremely stable as well. Turbo speed is somewhere around the 109,000rpm area. The spanner in the works for me is that prior to this Borgwarner and StraightGate, the car was tuned on -5 twins at a diferent tuner, and he also had issues controlling the boost with it spiking around the same rpm range, so to me this sounds like the same issue and it can't be anything on the turbo side as this was all changed and I think the behaviour is extremely similar, if not the same. We also removed the mac valve and did a run on wastegate pressure and it still spiked and had the same behaviour. My thoughts on possibilities are: Boost Leak VCT Cam Gear isn't reliably activating consistently - (On this however, we did a run with the VCT disabled and the boost still spiked) Turbosmart BOV is not handling the boost? However this seems unlikely to not be able to handle 20psi. I have a couple of logs that I can't make sense of if anybody knows how to read them and can obtain further logs of other parameters if they are not enough, happy to pay for anyones time. The dyno readout with the power figure is the most recent last week. The other picture is from two weeks prior to that where we couldn't break 400kw (we removed the cat), however the issue of the boost control persisted. @Lithium @Piggaz @burn4005 @GTSBoy @discopotato03 I've tagged those that were quite active in recent pages here, no disrespect to those that know turbos well but I missed tagging. Cheers
    • I recently purchased a 2018 Infiniti Q60, which has an SD card navigation map. I can see my system has options for real time traffic updates etc, and am wondering if there is something I can purchase to get this working? I can see there are at least updated maps for USA and Canada, but nothing for Australia. Surely Infiniti took changing road systems and city expansions into account when they decided to use an inbuilt navigation over Android Auto/Apple Car Play, or are we doomed to drive on streets that don't exist in the navigation system if you drive to a new area?
    • Luckily I didn't put in etch primer as I just found out it's not compatible with my body filler lol. Also just need to sand the panel anywhere between 150-400 grit so I'm in the clear there. It does say to not apply to soft old paint, I assume that means paint that is flaking, peeling,etc
    • @dbm7 and @GTSBoy thank you both very much! will give that a shot!
