I'm Looking For A New Car Need Sum Advice
I already got plug and play Link ecu G4X. Main concern is that the de loom works on s1 motor or not? I already rewired injector and coils loom to suit my bosch injectors and bosch vag coil. I鈥檓 not running any Iacv. For cas running the nz wiring kit i bought the neo plug one so it suits the wiring but don鈥檛 know it works or it doesn鈥檛 matter they work the same on every motor. For wastegate solenoid do i need to wire straight from ecu? What can i do for iat sensor to work or same run from ecu? For Vct solenoid, right now i got s1 vct solenoid on motor so do i need to remove neo connector and add s1 connector to work? Any other thing i missed i need to do to make the motor working on de loom. Any different mechanism on neo vs s1?
By GabsReDeal 路 Posted
Yes I was planning to get it to a tuner with a dyno, but they told me to wait till September because the heat really started now and it is not ideal to do it in this heat. -
Next week man, no rush on the postage
By Celticsfan03 路 Posted
Hello everyone. I believe I have s1 headlights but I just wanted to make sure and getting confirmation from you all. Thanks in advance for your help!
