Hi guys,
Since I have a series 1 front bar, there is alot of the front bar blocking the cold air hitting the intercooler.
I did a quick photo shop of what I want to do.
I will make it all neat ofcourse with fibreglass etc etc, but I was just wondering what you guys think, will it help in terms of performance? I don't really give two sh!ts about the looks, I'd prefer to keep it looking standard providing that it doesn't hinder my performance?
As you can see it covers about 50% of my intercooler, which I think is alot.
So, will I get better performance by doing what I have detailed in the pics attached?
Cheers
did the same thing to my car on the weekend.
took the front bar off, jigsawed out the number plate cross bar. used a saw blade and dremel to neaten the edging. i will be fibreglassing the cut bits to make it even and painting the lip and cooler black most likely to try and hide it a little while still having decent airflow.
i also used a dremel to mount my number plate off to the side using the standard clips and bolts.
i'll try and get a pic up if you are interested. but its not finished off yet.
Make sure you use epoxy resin to glass it, not the cheap polyester stuff.
Better still trim bits of the plastic offcuts to fit the gaps and get them plastic welded into place
cool thanks for the tips
didnt even think about using the plastic off cuts. they are in the bin now haha
a pic would be great!
Cheers
is that a standard S1 front bar, mine is the same and from other pics i have seen i was under the impression that it was an m-spec, if it is standard them im happier because i have lost one of my grilles and it will be easier to find if its standard.
WTF are you on about....?
I have no idea what you just meant..
    • Let's hope that's not a copy pump either. There were so many copies of them back in the day.
    • Damn it, I was at work last night, and stayed in a room there during the storm with the car outside, but undercover, I just went downstairs and well....there was a large steel locker that has come from some place last night, it wasn't anywhere I could see yesterday, and yeap, it landed on the fraking car....of course it did..... LOL So, I'll need to take it back for paint and panel, luckily it was only the boot that took the hit, so it could have been worse Serves me right for staying at work and getting on the cans with some of the boys
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
