r33 gtr rims are 9inch wide +30 offset.
They will more or less line up with the guards on a r32 gtst. If your car will be lowered, you will most likely need to roll the guard lips.
No spacers are required.
I currently have 8inch +30 rims and have had trouble of scrubbing on the front. Im sure if i put 9inch on the front id have more issues. Although that could come down to my damper/spring rates of my suspension.
Picture ive found on the net;
do they fit fine or did you need spacers? did you have any problems with them?
haha mate, they come off a R33 GTR, they are going to fit a R32 GTS-t. and yeh as Renkin said, 17x9 +30, perfect size and offset for a R32 GTS-t imo, will stick out of the guards slightly, nothing a guard roll wont fix though.
yeh, R33 GTR
ive had R33 GTS-t stockies on my R32 before and i felt like kicking it and throwing it in the gutter they looked so bad. using ur logic, that should be a pretty accurate reflection of the car they came off :D
yeh, R33 GTR
ive had R33 GTS-t stockies on my R32 before and i felt like kicking it and throwing it in the gutter they looked so bad. using ur logic, that should be a pretty accurate reflection of the car they came off :dry:
I currently have r33 gtst stockies on my r32. It looks fkn horrible. How could they make such ugly rims. :D
R33 GTR rims all the way - that red one looks fkn mad!
You will need to roll the lip on the rear guards and remove most of the guard lining in the front guards but other than that it will fit fine
One of my friends has R33 GTR rims on his R32 and it sits quiet low (rolled inner lip on rear guards, removed guard lining on the front) - I'm sure he wouldn't mind me posting up some pictures of it
Theres more in the R32 pix thread
    • So, good news and bad news Bad news first: The intake plenum is lost in the mail apparently, I haven't paid for it yet, and MX5 Mania are still chasing it up, farking 'Merica postal service  Good news: Any retune will be free if and when it turns up,  I'm still keen for them to throw it on The car goes noticeably better, with only the typical initial take off thingie from a choppy cam and manual transmission, but giving it just a little more RPM than before gives it a smooth take off (and hour or so of peak hour traffic sorted that little skill out) Car made around 145kwatw & 225Nm (Intake may get me to 150kw, maybe....🤣) Weirdly, 145kwatw is the same max power that my standard 2015 WRX STI made a few years ago The cam really comes alive from around 3.5k and keeps making power and holds it flatish all the way to 7k, whereas before torque would drop hard around at 4.5k Drive home was sadly in peak hour, although I did get a little clean air here and there to wind out 1st and 2nd a little bit, and whilst the gains aren't anything for the "boosted boys" to be impressed at, the thing is a blast to drive The sound in the vid is poor, as it is in a undercover yard at work, but, outside, in the wild, it sounds awesomeballs to my ears with all the choppyness I consider it money very well spent for the outcome  Cam specs for reference (Basically the biggest you can fit with stock pistons) 20250417_171807.mp4   LOL, I don't think I will ever grow up
    • Swap the injectors around and see what happens. If the misfire follows the injectors then that's a signal, if it doesn't it's probably not the injectors.
    • R33 with RB26 seems to go off of learned voltage for idle. Seemed like whatever the baseline voltage was once ECU first gains power will be the idle voltage. With ignition on unplug/replugging the TPS would relearn the idle TPS voltage.
    • Have you confirmed the 2 pin coolant temp sensor on the motor is working properly? I've had a very similar issue when I forgot to plug mine back in many years ago.
    • Ok interesting i guess ill wait till using a manual gauge before making assumptions.
