I was just down at my local Supercheap to grab a six pack of plugs for my girl and apart from them not having any guide on Imports and the Bosch site on the net being useless, I am lost.
I have NGK Iridium "BCPR6EIX-11" in at the moment but I want to get the new Bosch Fusion plugs.
I think I need F1-6 but I am unsure especially sine they are $129 for the six.
It is for an RB25DET out of an R33.
Cheers guys
https://www.sau.com.au/forums/topic/213645-what-spark-plugs-for-rb25det/
I run NGK BCPR6ES in RB25's gaped at 0.8 mm
NGK BCPR6ES come in 1.1 mm gap (BCPR6ES – 11) and in 0.8 mm gap (BCPR6ES – 8)
Standard boost = BCPR6ES – 11
12 psi = BCPR6ES – 8
Up to 19 psi = BCPR7ES – 8
Over 19 psi = BCPR7ES – 6
^ Hope this helps
  • Like 1
  • Thanks 1
  • 4 weeks later...
I think the wrong plugs have rooted my coil packs.
I changed the plugs and not two weeks later I need two new coil packs.
I actually have an RB25det Neo motor and I am wondering what plugs to put in it?
I have Splitfire coil packs coming in a week and I will be running 10Psi.
Cheers,
Jarrod
yo siddr20....
use bkr6eya-11 there still $3 a plug...
or bcp6rya-11 if u can get those ones..
ther anti-fouling plugs..lol
hence the "ya"!!!
:nyaanyaa:
anyone try using denso plugs?????
which is the standard plugs in Toyota..
i've used iridiums.. bkr6eya-ix
didnt do much of difference..just cost more...
ur better off just buying standard plugs...
run the biggest gap you can get away with. if the spark breaks down (misfiring), you know you need to gap them lower. so 1.1mm is great if you have no issues. if not go down to 0.8mm. it all depends on how well your coilpacks work.
  • 4 weeks later...
the splitfires i recieved in mail today say it is essential to replace plugs with one colder heat range if you have any type of mod besides splitfires(pods,exhaust,chips etc) and should be resistor types,so of the plugs mentioned in this thread,which would be more suitable?
BCPR7ES – 8 or 11
  • 1 year later...
  • 2 years later...
  • 9 months later...
Dig dig dig..
Sorry guys thought id dig instead of starting whole new thread.
I am now confused on what plug to use on my stock R33 RB25DET. It has a aftermarket exhaust (3inch i think) Pod, getting a BOV installed and thats it. Boost controller and a FMIC intercooler will be installed and running on 11 or 12psi with standard turbo.
Which one would be best for daily driving if i gap them to .08
BCPR6ES
BCPR7ES
bkr6eya-11
Or if anyone can recommend a good plug thats not $20 a plug that will be great. Cheers
Dig dig dig..
BCPR6ES
BCPR7ES
bkr6eya-11
you already have a blow of valve. Please don't install a different one. ○_○ ......Do you understand the difference of the plugs? The higher the number the colder the plug. I don't see a reason why you would need a cooler plug.
Edited by superben
BCPR6ES (they should be 0.8mm gapped). If the shop doesn't have it, go somewhere else. If you have a feeler gauge, you can gap them down (stores usually stock BCPR6ES-11, the 1.1mm gapped ones). Run 1.1mm gap (factory) if you have new coilpacks.
Oh and Ben yeah I knew it was a different heat rating but when I was doing some searching there was a thread that people were telling a guy to buy the 7s then I came in this thread and its all different plugs so that's why I got a little confused on what to use
Ben I have NGK BCPR6ES-11 plugs so its the 1.1mm gap as you know :) I will re gap them to .80mm.
Nizmo so are you saying that I should leave the 1.1mm gap if I'm running factory coils?
If you can run the 1.1mm gap without it missing then do it. The bigger gap the better. People only reduce the gap when they are running large boost or have old, weak coils that can't provide a strong enough spark
That's what I thought.. I will try the 1.1mm gap an see how I go. It only has 140k on the engine so coils might be fine.
Is 1.1mm and 0.8mm the only 2 gaps I can run or should I try lower the gap in 0.1mm increments like as in if 1.1mm doesn't work maybe try 1mm then 0.9 then 0.8 or is that pointless? I'm new to the whole boost scene so excuse my lack of knowledge haha appreciate everyone's help :)
    • Unfortunately haven’t taken pics yet after it was finished. All the edges are hemmed nicely, just had to cut holes for the gear shifter and seat bolts and seat belt bolts in the rear. The molds seem like they’re done with steam and a layer of glue on the underside to hold a bit of shape but still soft enough that it’s a good fit when it’s all pressed down.
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. I'm told as a chain breaks in it ends up regarding back about 0.5 a degree as the chain breaks in, making it bang on. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
