If you can run the 1.1mm gap without it missing then do it. The bigger gap the better. People only reduce the gap when they are running large boost or have old, weak coils that can't provide a strong enough spark
That's true, only reduce gap if you have to.
NGK BKR6EYA. = 0.8mm
I was running these on 10psi with stock ECU. No Problems.
Installed an SAFC 2 and my Tuner gapped them down to 0.7mm due to old Stock Coils. No Problems.
NGK BKR6EYA-11 = 1.1mm
I will go back up to 1.1mm soon as I just bought some Brand New Stock Coils.
This will be interesting...
That's what I thought.. I will try the 1.1mm gap an see how I go. It only has 140k on the engine so coils might be fine.
Is 1.1mm and 0.8mm the only 2 gaps I can run or should I try lower the gap in 0.1mm increments like as in if 1.1mm doesn't work maybe try 1mm then 0.9 then 0.8 or is that pointless? I'm new to the whole boost scene so excuse my lack of knowledge haha appreciate everyone's help :)
If they are the original coils at 140kms then they will probably be getting a bit weak.
And yes, you can just drop the gap by 0.1mm increments until it doesn't miss
If you want cheap BCPR6ES, get them off eBay
Just buy more than 12 at a time and it works out pretty sweet, $2.90 each delivered
http://www.ebay.com.au/itm/NGK-spark-plug-BCPR6-ES-plugs-BCPR6ES-tradeprice-2330-/330828510503?pt=AU_Car_Parts_Accessories&hash=item4d06ea7527
I just ordered 24 lol, works out to be $2.81 each.. :)
Well the 1.1mm gap works fine. Revs sooo much smoother now. Coils must be good :D Old plugs had a little miss before it revved. Doesnt miss at all during idle or rev. Have no driven it yet to test them under load but all seems fine. Thanks everyone for your help
  • 7 years later...
I've checked alot of places and I can't seem to find BCPR6ES spark plugs with 0.8mm gap I can only find 1.1mm and super cheap say (after rego checko) they are not a right fit for the rb25. After alot of searching and doing my head in I found BCPR6ES with a 0.9mm gap from justjap so that's what I went with... ?‍♂️ Stock rb25
Hmmm. You just set the gap to whatever you want with a very cheap tool.
I use those plugs with 1.1 gap and have zero issues. Drop gap if your coils are shit, otherwise leave at 1.1
So why so hard finding info ? Gapping copper/nickel and platinum plugs is trivial. Iridiums are the only ones you've really got to be careful with. In NGK if it has no - prefix at the end it is like this-
# heat range.
Copper/nickel plugs, the bcpr#es is pregapped to 0.9mm / 36 thou, there is no 0.8mm gap in bcpr#es coppers.
Platinum plugs BCPR#EP and Iridium plugs BCPR#EIX, are pregapped to 0.8mm / 32 thou.
A -11 at the end indicates an 1.1mm / 44 thou gap as an option, available in all of these plugs.
15 hours ago, Kiza said:
I've checked alot of places and I can't seem to find BCPR6ES spark plugs with 0.8mm gap I can only find 1.1mm and super cheap say (after rego checko) they are not a right fit for the rb25. After alot of searching and doing my head in I found BCPR6ES with a 0.9mm gap from justjap so that's what I went with... ?‍♂️Stock rb25
Also 5 is stock NGK heat range for RB25, 6 for RB26.
Probably why Repco / Supercrap say it's the wrong plug too.
  • Thanks 1
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
    • Thanks Paul I reached out to Autotainment but they no longer work on JDM cars as the guy who used to do the work moved on and is no longer doing that kind of work. I am talking with Level Up Audio though.
