Hey Guys, my name is Michael, resident in SA, pretty new to SAU and wondering if the team can help me this..
Theres a skyline r34 GTT i am suppose to buy this week except when I look at the pictures again the engine it looks different from other R34 turbocharged engines.
He seller said the neo cover is missing fair enough but it looks like a r33 turbocharged engine.
I will show you some pictures soon, but also I asked some guys to run a nissan fast vin check and it says Skyline GT, from here I assume it was a non-turbo then dropped a 33 turbocharged?
any help would much be appreciated.
The picture with the circles around 2 components i believe to be the same as the r33.
I guess what I am trying to prove is that this car was a non turbo model to begin with and then the owner dropped a r33 turbocharged engine.
I posted the car I want to buy (has circles on components)
A r33 turbocharged
A r34 turbocharged (has neo cover)
and the vin check Dicer checked
it says in the vin check RB25DE. almost 100% sure this means race bread 2.5L double over head cam elec fuel inj... if it said rb25det then it would be a turbo... so my guess is he got him self a cheep non turbo 34.. droped a 33 rb25 in and is trying to flog it off :thumbsup:
id confirm that too, no electronic throttle actuator like the R34...its a series 2 R33 motor. Also the car, its a non turbo car....which if previously not changed it still has non turbo brakes i would imagine.
Edited by Ryanrb25
its origional r34 n/a engine with turbo parts from an r33 bolted on
check if the brakes are turbo ones and see if its got an lsd diff
some non turbo r34s have different colour interior as well
also does it have the 3 center guages?
im not 100% sure but i reckon ive seen this same car for sale on ebay sometime last year for 18k?
from the pictures it doesnt look like turbo calipers
the diff would be non lsd
doesnt have traction control
wont have hicas
the suspension would be n/a type (r33)
the dash was probably changed to fit the guages as well
id avoid it buddy
hm crap,,
this car has got a full exhaust set up, adjustable suspension, front mount and pod.
thats all i know of at the moment.
would this car not be worth getting? and what else/financially would this car need to get it up to a normal gt-t.
I have to go to sydney to check it out next week but if any opinion that its crap I will change my mind.
full exhaust set up, adjustable suspension, front mount and pod is a waste of time if u have non turbo brakes
is it even registered as a turbo/gtt?
good luck with it buddy
hope u make the right decision
btw i saw this car for sale on ebay in january 2007 i even saved the picture for reference coz it looked sus
the guy has had a hard time selling it
Why bother even thinking about a dodgied up car? I think it is an R33 engine, as the traction control throttles are missing. There are plenty of local examples for reasonable prices.
i can confirm that by looking at the pics that r34 has a r33 motor in it.....i wont buy it mate....look around and you will get one thats even better may be....go and ask around for local importers.....i know of Dave from Elite Auto Imports and from what i have heard he gets some wicked cars in.....maybe pay him a visit....last time i checked he had a R34 GTT for sale....PM if you want his details
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
    • Sorry, I wasn't very clear.....just that the standard injectors are apparently good over 600rwhp/450rwkw which you won't get to on standard turbos anyway.....they are much better sized from factory than we are used to in RBs.
    • I'm not sure where you are, but United Terrey Hills has E85.
