I currently have a 2way nismo lsd that is shagged and open wheeling 90% of the time, now I've had a standard lsd centre thats shimmed up tight put in there. Now its shimmed so tight its a locker and its annoying me, understeer or oversteer when you push into corners, no neutral ground. It's good because It always spins up 2 instead of single legging but in car parks its clunks and chirps and is annoying.
Now the 2 way is shagged and needs a rebuild so is this going to have similar traits to the locker if rebuilt? eg chirping in carparks and being a pig to drive? I don't mind a little understeer in corners as long as it will power oversteer and not single leg in straight lines.
Basically the question is for a car that is 90% street 10% track am I better rebuilding the 2way or getting a standard lsd and shimming it up so its not quite locked? The car has ~150kw and being the average HR31 IRS it tends to still have trouble putting the power down even with 9.5s so a loose LSD is just annoying.
Edited by Rolls
hey mate mine does the same i dont have a 2 way but put some good diff oil nice and think and it will get rid of that cluking got rid of mine
The clunking is my bushes and everything else straining when it tries to spin the inside wheel in low speed manuvers.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
