I remember reading somewhere on here in the past that someone had tried some large pc computer case fans on there remote mounted oil cooler, as they weren't able to find a thermo fan small enough. My oil temps aren't exactly out of control, but I do have a couple of 120mm and 200mm case fans from old pc's not put to use. Most pc fans seem to flow less than 50cfm, I've seen some jaycar ones that flow 100cfm but that still doesn't sound like it's enough to be effective?
Has anyone found a small enough thermo roughly 15cm's wide? (to fit a greddy oil cooler) that works?
Or, has anyone actually had good results from using a large case fan/s?
https://www.sau.com.au/forums/topic/213689-oil-cooler-cooling/
Yeah it's more of a boredom thing :laughing-smiley-014: (90 oil temp on cruise, doesn't go over 100 oil temp ever) I'd still like to see it back down to about 85 on cruise.
Relocated the oil cooler from behind the fmic, to being in the driver's footwell. I found that oil temps are slightly higher with no thermo fan drawing air through, even though it's in the air dam on the driver's side now.
Edited by silman
Have you ever though of getting it out on the bonnet...like a rex bonnet scope?
Seriously....having a higher running oil temp..ie around 90 to 95............not over 110...
can only work to help your motor sustain a better life.
Engine oil is not like water....it does not boil at 100.... :D
Boredom......can kill a man
Not sure a 120mm PC fan will do much, might not like being bolted a 1000C core either. Dont be fool into thinking a 12V PC fan is the same as 12v automotive unit. A typical 80amp alternator and 400amp battery allows quiet meaty motors used in the automotive area.
Have you got an aftermarket w.temp gauge, or PFC that shows temp? My understanding is, that your not likely to get your oil much cooler then your water due to how close they're linked (and the OEM oil<->water exchanger)
Maybe a automotive style 8" would fit on its side...?
Edited by GeeTR
I ended up purchasing a 7" thermo, will be doing an install this weekend and posting my results.
The pc fan thing was a joke, someone on here had actually done it but as i said, i can't find it in the search results and i can't remember what the application was used in.
As a matter of interest though, there are 12 volt fans for pc's, notably the 20cm Antec style used in there better pc cases.
nice idea - i wanted to do this to my auto trans cooler when i had my R32 but couldn't fit a fan to it given where it was mounted... my idea was to wire it co come on with a switch or with the standard radiator fan to cool it when at idle (eg in traffic on a hot day), and let it go off when the car was cruising
i plan on doing this to my intercooler (and oil cooler when i get one) - run one of those water sprayer kits that activate on a certain psi. if you were handy with the tools you could probably hook up one yourself with a button you press whenever you think your temps are getting a bit high.
my cousin had one of those kits on his rex and worked really well.
Well, it worked :D I purchased a flex-a-lite 7" thermo and mounted it to the back of the oil cooler. Oil temperatures dropped 6 degrees with no other changes. This is just an indicator of the difference with regular street driving.
I've got it controlled by a pivot fan controller, one spal 12" high flow fan pushing onto my air-con condensor, through to my radiator.
The other is the oil cooler thermo, pulling air through from behind the oil cooler.
This is in an RB25DET 180SX. I'd expect an even better result in a Skyline engine bay.
http://img444.imageshack.us/my.php?image=picture002cu4.jpg
http://img185.imageshack.us/my.php?image=picture001ej2.jpg
http://img185.imageshack.us/my.php?image=picture006oq7.jpg
but i dont understand you do u want to put a thermo behind a remote oil cooler? i just installed my cooler right behind me front bar and im not thinking its running a bit too cold when cruise. i think the oil cooler itself drops oil temp dramatically.
    • Oh, that's grim. Something bad has been happening there.
    • Put an endoscope down the hole and saw this. Not quite all around the bore but a good 60% at least. Chin to the chest and towards further disappointments I guess.
    • 2 does "sort of" applies, maybe......but looking at what parts would be needed for the swap to get engineered, registered, and insured, and basically that's everything under the car, the modifications the make it legal would be problematic and horrendously expensive, all for a street car that just cruises around and hits a few twisty roads on the weekends Also, from looking at the NSW rules and Regs, with all modifications that is required just to make the car safe and not twist itself to pieces, and then actually get registered for street use, may still be impossible nowadays As for 1, when you add in a fresh engine, fresh transmission, rear cradle and diff, tailshaft, suspension, brakes, cooling, and all the other fabrication required, your probably looking at up to $100k to do it right, all for a 20 year old MX5 that is over engineered and you would never be able to actually use the power it has on the street, much like your beastie, which I love, but you actually track that thing and can use all of its powers in anger, in a safe environment  Hell, the old Bogan Cruise Ship had more power than I could use on the street, and in hindsight, I went a bit silly on that thing, it didn't really need the 500hp it had for what I actually used the car for, it was fun, but basically unusable on the street if you value your licence  As for cams, yeah, I'll probably book it in for them to get installed and tuned soonish, like next month after MX5 Mania are back at work....... and yes, I've already sent a email to bin the turbo quote and quote instead to install cams and a new Fluidampr balancer that will suit the 2.5 better than the OEM 2.0 balancer that is swapped over for the 2.5 install, as the balancer needs to get pulled to time the cams it's a while your in there sort of thing I did think a bit about flex fuel for a laugh, but being na, and no where really around locally anymore to get E85, I've binned that idea, so no sweet sweet corn smells are set for the car I wish E85 was more of a standard fuel, it's better for the environment, better for tuning, plus that sweet sweet smell we all love As for fitting in the family, that's not needed, as everyone in the family already owns a car that can seat 5 humans comfortably enough, the MX5 is "my toy" As for buying a car that is already built, nah, I would rather pick and choose my parts, I enjoy the process, and in the big picture, the additional cost is well worth the enjoyment, and the occasional frustration, I get out of doing it, albeit with other people spinning the spanners, and me, just paying the invoice 🤣
    • Excuse me, but 2) does apply 1) Would also apply if you consider how much is spent in the alternatives. Also there's the option of 3), buy one pre-built that you can put your family in (it's me, it's my car)   That said, I went on a ~500km drive the other day. I didn't use anything more adventurous than 3rd/4th gear at about ~3000RPM and 50% throttle and I was going as fast as anyone has any sense doing on a public road, with enough grip to the point where I didn't want to go any faster. I was obviously under the limit of the current car etc etc. MX5 with 2.5 N/A to achieve the same speed would be more fun for any road scenario. Maybe consider cams. I wouldn't boost it. The use case is just not there and it won't actually make the car more enjoyable unless you really do plan on wringing gears from 1st to 3rd (at least) at 100% WOT on a public road to 150+kmh.
    • Great if: 1. You had all of the money for everything else that is required  2. Lived in a country where you could actually do this and drive it legally on the road Sadly, neither applies to me As for the turbo, I am having second thoughts, mainly for engineering/registration legality reasons and insurance  Not saying I've finished doing stupid things that I probably should do to the MX5, but boost, and V8 engine swaps isn't on the cards Strange, but true
