So I have a Skyline and its not feeling quite as perky as she used to.
I'm thinking about pouring about 10k into it. In that 10k is 1k of Stereo and 2k of Suspension (SK's Springs, Bilsteins, Sway bars) . Leaving about 7k on gofast bits/install/tune.
Current mods are as follows...
FMIC
PFC
AVC-R
Bosch 040
3inch turbo-back exhaust.
I've sorta decided I want a new turbo - as the people who are going to do the work tend to think that its a lot more reliable at getting good figures (he felt that whilst sometimes you get good results out of hi-flows, othertimes not so as much as he'd expect) - also, the engine has 110k on it, which means that poor stock turbo has been huffing a bit more boost than it should have for at least 35k of those.
Restrictions?
* Stock-Airbox (although I am quite keen on getting a CAI box setup of some description...), I really don't want a pod and If it can stay in the Stock-Airbox, all the better.
* Staying internally gated
What I want?
Currently (before I took the Pod off) I was getting ~200rwkw at 15psi. I want more (duh), but It also has to be on the responsive side of power. I don't want something that doesn't start because its too cold, is unbearable off-boost etc. My missus drives this to work 5 days a week, and I do the long trips/weekends :D.
I am sorta keen on a set of Cam's to go with the mods (injector's, turbo+bits to make it fit, Z32, CAI mod) as the old V8 guy in me thinks it will aid in making sure things are a bit more responsive - am I right in this belief?
I've had a poke around and people seem to be making ~270-300 rwkw with this kind of setup, with graph's that look quite sporty between 4200-6700 rpm.
Edited by nsanity
https://www.sau.com.au/forums/topic/213726-recommend-me-an-upgrade/
HKS T51R SPL.....I love these threads.
That's because you don't read his requirements and post up shit! :D
I would go with what PaulR33 advised, would be a good package to meet your requirements, with acceptable response. If you have the money, get a set of Tomei Poncams and while you have the head open fit some Tomei valve springs. While you have it almost all apart, a quick reco/freshen-up of the head may not go a stray (valve stem seals, etc)
Cams will definitely help mid to high rpm range, but are not necessary to make good power. They will make less power in the low rpm range, but is hardly noticable.
So a shopping list consisting of
HKS Turbo Kit - GT Sports Pro (Nissan - Skyline - ECR33/ER34 - GT2835 Pro S - A/R 0.68)
Tomei Air Flow Meter - Z32 (Air Flow Meter Z32)
Tomei Pon Camshafts (ECR33 Series 1 (RB25DET) - Duration: IN,EX 256 Lift: IN,EX 8.5mm)
Tomei Valve Springs (Nissan - Skyline - ECR33 - RB25DET - Type A - Lift 8.80)
Nismo High Performance Injectors - Yellow - 555cc
or thereabouts would do wonders? I notice the A/R on the HKS kit is lower compared to Paul's recommendation...
I assume I'll need some alternate manifolds, or are the 2835's a straight swap?
That's because you don't read his requirements and post up shit! :DI would go with what PaulR33 advised, would be a good package to meet your requirements, with acceptable response. If you have the money, get a set of Tomei Poncams and while you have the head open fit some Tomei valve springs. While you have it almost all apart, a quick reco/freshen-up of the head may not go a stray (valve stem seals, etc)
The reason for my response was the fact that there are about 10 of these threads per day. Searching is one of if not the best way to get an answer as subjects like this have been covered time and time and time again.
To the moderators , is it worth having a small number example builds and graphs - sort of along the lines of what a typical Skyline owners opts for and post them up in a separeate section ? I know this overlaps with the turbo results section but just a suggestion . Might give the new punters an idea of what to expect ?
A .
HKS GTRS turbo, strait bolt on, internally gated.
Injectors
Aftermarket panel air filter
I have similar mods to you aswell as what i have listed and am getting around 275rwkw, my next move is cams
So you are getting 275 rwkw with the standard air box?
A .
To SAU Mods:
+1 Like "N1GTR's RB26 rebuild" thread, or "Birth of an RB25" thread. They were great reads.
What if there is a new subsection titled "Engine builds" for example, with subsections within it for different engines, and another series of subsections for different power brackets OR stages (std engine/forged engine/race engine) OR turbo choices. Will save lots of leg work for heaps of people.
It could be like the engine upgrade section BUT can be more in-depth, with pictures and open discussion (unlike the no chit-chat policy :rofl: ).
All this needs is approval- and donators willing to give their time to create the threads :P
Edited by R338OY
Injectors
I like this one... That will get you response, lots more power, and probably save you money.
Make sure its the GTRS turbo kit though.
My 2c
Definitely go a larger A/R as paul recommended. I don't think the one you posted would be too street friendly.
For your suspension have you looked into any of the Jap coilovers? I was going to SK suspension but have now opted for a HKS coilover from doing a search and recommendations of people who have been in and driven cars with those coilovers but then that also depends what you're looking for in your suspension...
The comfort side of performance. I don't lower my car's - speed humps exist and you have to deal with them :D
Everything I've ever read has said that Jap Coilovers are built for roads that aren't in Australia - you know those smooth and maintained ones :D
I used to be in Canberra (now Melb) and every other month someone was selling their Tein's or what have you to pay for their chiropractor.
breaks, suspension!!
who does?
using bare hands?
anyway, nsanity sounds like you have your head on straight and "kinda" know what you are after and what you will need.
This is one of the BETTER "what mods should I do" threads
I agree with the new section.
kinda like a "readers rides" but more so a members builds.
make it so anyone can create a thread, maybe provide a template for car, engine, mods.
then only the thread started can update.
anyone who wants to ask quesitons can PM the person.
that way you get no chit chat, and you have a full diary/blog type thread of each member is doing/has done to their automobile.
I am yet to read a better thread than Godzilla32's "My restoration" thread.
And that is stickied in the general maintenance section.
surely it needs to go in the POOL ROOM..
and that there is what the new section should be called.
:D
    • Major thread necro but how bad of a job is it to DIY? Looking at it online it looks like if you reuse your ring and pinion as long as those are in good condition it should be fine to just pull the axles/front cover and replace the diff that way? Or should I be replacing everything and doing preload measurements/gear mesh testing like the factory service manual mentions for the rear diff?
    • in my list I had the R33 GTR as the best Skyline. Infact I had all GTR's (33>34=32), the NSX, the GTO, the 300ZX, the 180SX, the S15 better than the FD RX7. I had the MR2 and the A80 as 'just' better. I also think the DC5R Integra looks better but this is an 01 onwards car. I also think the FC>FD. It's almost like aesthetics are individual! The elements @GTSBoy likes about the FD and dislikes about the 180 are inverse in my eyes. I hate the rear end of the FD and it's weird tail lights that are bulbous and remind me of early hyundai excels. They are not striking, nor iconic, nor retro cool. The GTO has supercar proportions. I maintain these look much better in person (like the NSX) especially with nice wheels and suspension which is mandatory for all cars pretty much. Some (or all) of these you have to see in person to appreciate. You can't write a car off until you see one in the flesh IMO. Like most people we probably just like/dislike cars which represent certain eras of design or design styles in general. I also think the 60's Jag E type looks HORRIBLE, literally disgusting, and the 2000GT is nothing to write home about. FWIW I don't think the Dodge Viper Gen1's have aged very well either. You can probably see where I rate bubbly coupes like the FD. I know we're straying now but the C4 and C5 absolutely murder the Viper in the looks department as time goes on, for my eyes. Wouldn't surprise me if people who love the FD, also love the MX5, Dodge Viper, Jag E Type, etc etc.
    • I used to hate R31s, and any of the other Nissans that led up to it, and any of the Toyotas with similar styling, because of the boxiness. They were, and remain, childish, simplistic, and generally awful. I appreciate R31s a lot more now, but only the JDM 2 door. The ADM 4 door (and any other 4 door, even if they are unique compared to our local one) can eat a bowl of dicks. The Aussie R31 is also forever tarnished by their association with stereotypical bong clutching Aussie R31 owners of the 90s and early 2000s. I think the Nissans of the 70s (other than 120Y/180B/200B) are far superior looking to the 80s cars. The 240K era Skylines are boss. The same is broadly true of Toyotas. Hondas don't ever register in my thinking, from any era. Mitsus are all horrid shitboxen in any era, and so also don't register. Subarus are always awful, ditto. Daihatsus and Suzukis also don't generally register. They are all invisible. I think the SW20 MR2 looks fiddly. The 3000GT/GTO is like that but way worse. Too many silly plastic barnacles and fiddly gimmicks ruined what could have been a really nice base shape. Kinda-sorta looks like a big heavy ST165 Celica coupe (and I'm not sure if that's a good thing or a bad thing). I think the 180SX is dreadfully bland. It's not bad looking. But it has no excitement to it at all. It's just a liftback coupe thing with no interest in its lines, and bad graphical elements (ie wide expanses of taillight plastic on the rear garnish). The S13 Silvia is a little better - getting closer to R32 shapes. But still....bland. S14? Nope. Don't love it. S15...a little better. Probably a lot better, actually. Benefits from not being like a shrunk in the wash R34 (where the S13 was a shrunk in the wash R32 and the S14 looked like a Pulsar or something else from the stable on Nissan mid 90s horrors). The Z32 was hot as f**k when it came out but hasn't aged as well as the A80. Keep in mind that I think the R33 is the most disgusting looking thing - and out of all the previous cars mentioned is objectively closest to my precious R32. It's just....real bad, almost everywhere you look. And that is down to the majority of what was designed in the 90s being shit. All Nissans from that era look like shit. Most other brands ditto. In that context, the FD absolutely stands out as being by far the best looking car, for reasons already discussed. Going behind the aesthetics, the suspension alone makes it better than almost any other car.
    • If they just called it the "Mazda Tiffany", it would have been spot on.
    • Yup but for me its the HR ! Cut my teeth on the old holden 6s in the day ! And here's me thinking in the day it was also the 300ZX and the Mitsubishi GT3000 ! All, as well had good lines, but always seemed to need finishing off, style wise.
