So I'm doing an RB26 conversion on my S13. I have spent all my money on the engine setup and don't want to spend money on an R33 gearbox when I have 2x r32 GTR boxes sitting here already.
I've removed the transfer case already and all the internals that seem associated with it. What do I do in terms of the oil pump in the rear?
Any info from someone that has done this would be much appreciated.
cheers,
Greg
i guess u cud bin bits and stuff around with removing the transfercase to save weight.
but just remove the front drive shaft between the transfer case nd front diff, nd u mite need a custom tailshaft/ use da gtr one if its da same length as the s13 driveshaft
All the inners that are associated with the transfer case have already been removed and the transfer case has been cut off as it probably wouldn't fit in the S13 tunnel with it still attached.
  • 4 weeks later...
I have done it in my GTR, car is running 630rwhp and loving it.
I welded up the hole left by cutting off the tranfere case with 10mm ally plate then surfaced the gearbox and the tranfere case to be a perfect fit. I then put a litre of diff oil in the tranfere case which with acceleration and decelleration should keep the bearing oiled, they are not noisy yet and that included a thrashing all weekend at powercruise.
One thing to watch out for is make sure tou put the selector pivot back on the selector shaft the right way up, otherwise you will be pulling it apart to do it later, its simple mistake if your not paying attention. ie I did it on mine at around 2am when I should have been in bed instead of working on cars haha.
The oil pump is only there to clamp the wet clutch for the 4WD system. So the short answer is bin it.
incorrect you need it to lube the rear bearings. I have done about 6 of these now greg if you need one done. i just did one for type M in dandy.
this is one of many threads ive posted pics.
http://www.skylinesaustralia.com/forums/Rb...amp;hl=transfer
What's your number Trent?
I also need the motor built and I'm over waiting around for people.
Sorry my bad.
I assumed you were referring to the ATTESSA pump that plugs intot he back of the gearbox/transfer case.
The internal oil pump inside the gearbox should be kept.
  • 4 months later...
    • Update Issues 5 (plus #4) - 10 After making a claim about issue #4's missing part, DeAgostini Japan sent a whole new issue #4 and it arrived about 2 weeks after that. That was back in early March. It took another 4 weeks to receive issues 5 - 13 though. This update is for issues 5 - 10. Ove the 5 issues the front left suspension and most of the engine have been completed. The quality of the castings and fit of the parts is quite good, it seems better than DeAgostini's BNR34 Skyline GT-R from the Fast & Furious 2 movie, which (to me anyway) doesn't seem to have as tight tolerances or quite as accurate castings.  Each issue has a lot of info about the 1989 - 1993 Skyline range and other Nissan models from that era, but the focus is on the BNR32 Skyline GT-R Nismo and the various racing it did in Japan, Europe (Spa 24hrs) and of course Australia. I've included some text translated with Google Lens in some photos and will add to them if there's anything worth including.
    • If it's for a SR20, make sure it's not the American Poncams, might as well call them Poocams. Had a set in a friend's car, all scuffed up after a few track days. Like the metallurgy Tomei USA used is junk. Went back to JDM OG Tomei Poncams, no issues till now.   Tomei USA is not the real OG Tomei.   Random rant over, fk the US of A, bunch of c u n t s.
    • Most of the industry in North America either runs on Siemens or Allen Bradley. I have two redundant S7-1500's on my desk right next to me for simulation. Siemens has been losing ground though since Stuxnet, as cybersecurity is a big thing. In my line of work that is federally regulated, you must by law have a cybersecurity management program in place and its audited and inspected every so often.  I work with Emerson PLC's daily (RX3i's) and have done large biogas/refinery projects with their DCS's. Their PLC's are somewhat OK minus the way they do PLC redundancy (You have to download on both PLC's separately every time you make a change )  As for their DCS's... you'll be limited financially first before anything else stops you. Costs are exorbiant at roughly 10x what it would cost you to do with any other system (e.g AB PAC).  1990's, those suckers are brand new haha! Kraft-Heinz (An old client when I use to work for an ESP) still runs Siemens TI505 PLC's from the mid 80's. Ohh how I don't miss working with those... you could only do a certain number of online downloads until it's "Change" buffer would be full and you would then need to go offline to do a full download. There was no warning of when this was coming up and it generally would happen when you would go in at 2am to make changes before production -_-.
    • Unfortunately, not only is that not the case, one of the main "Selling points" of safety over comms is they clearly state in writing that there's no need to segregate safety networks from non-safety networks. It always gets intermingled with everything else on an ICS/OT network.
