  • 4 months later...
can you share pictures of the out come? I need to see if it really work,.
Got mine in today, the box looks like a truck gearbox when bolted to the RB.
Installing it into the car (32 GTST Rb30det) was a pain. The bottom end and box was put in first as there was no room to do so with the head on.
No bashing was needed at any point and the shifter lines up with the hole as factory. The transmission crossmember is being mod'd atm more pics to come...
http://i223.photobucket.com/albums/dd81/30...pg?t=1234614932
http://i223.photobucket.com/albums/dd81/30...pg?t=1234614973
  • 4 years later...
hi im in the process of turning an r33gtr gerbox rwd
but i just need a little help
i have the transfer case off but what i need to know is what parts do i need and what parts do i dump?
its all still bolted together with the oil pump ect how do i about sapping all the transfer components off the shaft ?
  • 4 years later...
Hey guys,
Sorry to revive an old thread, but i am currently going down this path as well as im converting a 180sx rolling shell that i purchased to run the RB26 engine out of my GTR (its getting an upgrade) and converting the GTR 5 speed gearbox to use also.  Im all good with the transfer case modifications and have the shafts apart etc, my question is around the speed sensor.
Does anyone know what speed sensor to use in the transfer case?  The standard GTR one is obviously a cable driven sensor that connects to the speedo, but the 180sx dash uses the electrical type sensor.  I have heard that the Z32 sensor is compatible but havent been able to track one down as yet to test it out.  Im also going to be running an R32 GTS4 4.3 ratio diff so would be trying to find one with that calibration if possible.  The gearbox im converting is actually from a GTS4 as well, so the speed gear should be 4.3 already if they are different.
Cheers!
Edited by SLVR32GTR
8 hours ago, Griffin said:
I'm also looking at doing this and trying to work out how to get the speedo working in an r33 gtst.
From what i have found searching, i would say that the R33 GTR speedo sensor should work for you mate.  The R33 GTR sensor is electronic and will bolt straight into the 32 GTR transfer case as they are interchangeable.  I am looking to source one from Japan as i think it should solve my issue with getting a speed signal to the S13/180sx dash as well, i just may have to use a trim module to fine tune the accuracy.
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
    • You must be fun at parties.
