Micolour Sau-vic Deca Motorkhana - Sat 3rd May 2008
Scotsman
 Share
Proudly Presents:
Micolour SAU-Vic DECA Motorkhana
When : Saturday 3rd May 2008
Where : DECA - Shepparton, 145 Wanganui Road, Shepparton, VIC 3630
Cost : $75
Max Entries : 50 + Reserves
Entry Form & Supp. Regs. : Click Here
Results - Click Here
Event Schedule:
Anyone paying by cheque MUST make the cheque out to Skylines Australia Victoria. Cheques made out to anything else WILL BE REJECTED.
Please support our sponsors : Micolour - Custom Refinishing, 7 Dissik St Cheltenham 3192, (03) 9555 8011.
  • Replies 149
Entry list:
1 Mick Eichorn R32 GTST
2 Tim Williamson R32GTST
3 Andrew Richmond R34 GTR
4 Chris Thomson R33 GTR
5 Peter Blythe R34 GTT
6 Dave Lee R33 GTR
7 Aaron Tan S15
8 Scott Bailey
9 Muhammad (Ziad) EVO
10 Nick Edlin R33 GTST
11 Ryan Bell 180SX
12 Mark Firman Team Datto
13 Russell Cunningham R32 GTST
14 Michael Dessmann R33 GTST
15 Sam Lothringer R32 GTST
16 Justin Marcus R33 GTR
17 Leigh Davidson Team Datto
18 Darren Golding WRX STI
19 Troy Galt Team Datto
20 Iain Thomson Forester
21 Nathan Lawrence R33 GTR
22 Alan King Mini Cooper S
23 Gary Matthews WRX
24 Lee Dimitrijevski 180SX
25 Alycia Matthews WRX
26 Rob Nigro R32 GTST
27 Sean Power R32 GTST
28 Gareth Evans R32 GTR
29 Michael Tomkins Mazda RX7
30 Brenton Homer WRX
31 Antony Ivancic R33 GTS
32 Matt Phillips Banana
33 Sandeep Abeywickrema 300ZX
34 Adam Newton Big Red
35 Matt Sampson Big Red
36 Robert Chen S15
37 James McMahon S15
38 Mat Cross Corona
39 Martin Sullivan Bluebird
40 Peter Vakras R32 GTR
41 Robert Dromi EVO
42 Peter Canfield WRX
43 Matthew DeBenedetto R32 GTST
44 Stewart Burns RX8
45 Aaron Foo EVO 9
46 Chris Stacey R33 GTR
47 Dillon Loos R33 GTR
48 Phil Nikoloski R33 GTST
49 Khoa Nguyen
Reserves:
1
2
3
this is one where you need to buy a cams license on the day (if you don't have one) yeah?? and a helmet and fire extinguisher??
roughly how long does it take to drive to shep?
Daniel - you can use CAMS or AASA on the day (if you use CAMS, you must have current club membership) and yes you will need a helmet and extinguisher, but you could probably arrange to borrow a helmet from someone.
Takes approx 2 hours to get to Shep from central Melb - depends of course on where your located.
I would advise signing up for your SAU Membership sooner rather than later.
DECA for the uniniated - A day at DECA Shepparton using the skid pan and the back tracks. Traditionally (cannot speak for this one), the back track has two variations, Long Wang and Short Wang which are timed against the clock in the morning. The skid pan is single use in the morning against the clock (by single I mean not against other cars but a passenger is permitted provided they have either entered or signed a waiver). The morning is split into 2 groups with half doing the back tracks and half doing the skid pan, then rotate before lunch.
<- This is the basketball court on the Long Wang
The afternoon comprises or more "battle" type events with one car pitted against another on a run up the skidpan and back down again, kind of slalom type event. This takes us through from 9 until about 4.30-5.00pm. From there, we all meet up at Taco Bills for dinner and drinks before hitting the town.
Hope this helps :)
 Share
    • People still have Skylines? I thought they're non-existent now.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
